Headlight not working?
Old Jul 11, 2018 | 06:43 PM
Ralphie68's Avatar
"I don't know how that is possible."
Now you know my confusion! I think I'll just stop by the Chevrolet dealer tomorrow and ask the guy at the parts counter how this could happen.
I used to be an electronics technician in the Air Force and for many years in civilian life, and I know how to read a schematic. Thanks for posting them, but they don't tell me how this could be happening.
Wish me luck!
-Ralphie
Old Jul 11, 2018 | 07:07 PM
Chewed up ground wire...
Old Jul 11, 2018 | 07:29 PM
That's not what you said before. You said one light on in daylight, and when you switch from 'auto' to 'on', there is one light on.
Old Jul 11, 2018 | 07:52 PM
Ralphie68's Avatar
OK, when I first posted, I didn't know about the DRLs. Now that I do, it clarifies my problem somewhat. At startup, the low beams come on for a few seconds, then go off. In the daytime, when the engine is running, and the transmission isn't in park, the left DRL comes on by itself. After dark, both low beams come on. When the switch is made to high beams, both high beams come on.
Sorry for any confusion. God knows, nobody is more confused than I am at this point!
Greybeard, the chewed up ground wire is my best bet at this point. Thanks for the tip!
BTW, any ideas where that wire might be?
-Ralphie
Old Jul 11, 2018 | 08:00 PM
-Ralphie
There is a ground wire for the right headlight that comes all the way over to the left side inner fender. (for some odd reason) It runs across the radiator support.
Old Jul 11, 2018 | 08:29 PM
I think you still have it wrong. The DRLs come on when the trans goes in gear. The headlights go on at dusk or when the wipers are on or when you turn the switch to on. I never noticed the lights flashing on when the engine starts.
I think you are still mis identifying which lights are on.
All of the lights on each side share the same ground; the right side goes to the left side of the radiator support, the left side goes to the left strut tower.
Old Jul 11, 2018 | 08:50 PM
Look in here
https://www.chevyhhr.net/forums/how-...cations-56504/
Old Jul 11, 2018 | 10:47 PM
gio89kid's Avatar
Well if it’s anything like my HHR the DRLs are the highbeams.
So power on with DRLs (lower voltage highbeams), turn on lows with one bulb out, then put on brights with both bulbs working.
Sounds like you just need to replace the bulb as your lower wattage filament is out.
You can also test this by pulling the DRL fuse like mentioned earlier.
Old Jul 12, 2018 | 08:12 AM
Somebody messed with your wiring. DRL is low beam, look at the wiring schematics.
Some cars have low voltage high beams, not HHR.
Old Jul 12, 2018 | 08:33 AM
gio89kid's Avatar
Well the easiest thing to do now is to pull the DRL fuse and tell us what happens.
