Headlight problems
Old Apr 6, 2023 | 08:52 AM
Hhrandme's Avatar
I did the radio with the gm lan 04 cause it has factory amp and the bulbs came pre installed into a set of oem headlights assembly that my gpa bought for the car about a year ago
Old Apr 6, 2023 | 08:54 AM
Hhrandme's Avatar
It might not be the ls I could be saying the wrong thing here but I will check those grounds in the pics u sent in a little bit and let you guys know what I find hopefully it's a ground issue
Old Apr 6, 2023 | 09:35 AM
Does the valve cover have VVT on it? If so, it is a 2.4l not 2.2l.
I would pull the bulbs out to see what type they are, LED, etc. Strange they are not burning out.
Old Apr 6, 2023 | 09:37 AM
Hhrandme's Avatar
I'm not sure off the top of my head but that's what I was thinking those are some tough bulbs lol
Old Apr 6, 2023 | 01:32 PM
Hhrandme's Avatar
Just got done messing with it those grounds were corroded not to bad but enough to mess with it and the bulbs were high output so I put the ones that worked fine from my 07 in it and so far seems too work just fine
Old Apr 6, 2023 | 04:28 PM
What is "high output"?
Old Apr 6, 2023 | 04:31 PM
Hhrandme's Avatar
They were the Sylvania blue lights and the wattages was different than the regular headlights that came with the car so they sell oem headlight assemblys with non OEM lights they were drawing too much power
Old Apr 6, 2023 | 07:24 PM
Weird, but you fixed it!! Awesome!
HHR09Horace
Jan 14, 2022 04:53 AM
HHRHeadlight
Nov 17, 2021 10:09 AM
goetylsd
Maintenance and Upkeep
59
Jun 19, 2017 05:55 PM
ruckdog60
Nov 23, 2014 02:50 PM
Uma
South Pacific
Oct 27, 2012 10:36 AM
