HHR Emblems
Just pull them off, they are stuck on with dual sided tape. If your having trouble getting them off I like to use a strong piece of string like dental floss to work them off. Just use the string to kind of cut throught the adhesive. Use Isoproyl Alcohol to clean up where they were. They can not be restuck you will have to purchase a new set. They shouldn't cost that much, probably between $10 - $20. Hope that helps.
DANSHHR
11
Apr 15, 2009 03:59 PM
