HHR LS Swap Rat Rod
Old Oct 25, 2017 | 03:27 AM
  #101
07azhhr's Avatar
Ratty - This looks like a fun project. Thanks for sharing.
Old Oct 25, 2017 | 03:43 PM
  #102
Cat Man HHR's Avatar
Originally Posted by RattyHHR
I'm figuring since I might be loaded down some days and just cruising on others, a watts link is gonna keep my rear centered better. Am I correct in thinking this?
Yes
A Watts will keep the rear centered thru range of motion, while a Panhard will shift the rear to one side, that can cause the rear to "steer" the rear end.
Old Oct 25, 2017 | 03:49 PM
  #103
Originally Posted by Oldblue
Correct, thats why NASCAR uses the panhard bar setup, with the driver able to adjust to control for traction
The driver can adjust the bar? Is this F1 racing? This is new to me.
Old Oct 25, 2017 | 04:19 PM
  #104
Monster Energy Cup racing,
Old Oct 26, 2017 | 01:06 PM
  #105
RattyHHR's Avatar
Originally Posted by 07azhhr
Here is a good read on what a panhard bar is used for. It explains how it can be used to adjust body roll for better traction.
Panhard Bar Explained - FMI Knowledge Base
Here is another one I just found.
What Does the Trackbar Do? - Building Speed
Great stuff, thanks for the info!! Got a big weekend planned for the HHR. Fresh wheel bearings and brake parts for the front so I can mount a couple wheels and tires to it and have it rolling again. Might try to get that Jeep steering shaft as well and get that taken care of. Need to get my 4 bolts through the frame and body, and start framing up the rear section.
Old Oct 26, 2017 | 01:07 PM
  #106
RattyHHR's Avatar
Yeah I think it's new this year. I believe one end of the bar is threaded and the driver can adjust it with a switch.
Old Oct 26, 2017 | 01:08 PM
  #107
RattyHHR's Avatar
Speedway has a universal watts link kit for $75. Seems like a decent price.
Old Oct 26, 2017 | 01:48 PM
  #108
Go for it, but rethink the 3 bar set up with it. Do your homework. Or ask your girlfriends dad to do it, LOL.
Are you going to use the electric PS of the HHR or run a pump to the Camaro steering box or just go manual box?
Old Oct 26, 2017 | 01:51 PM
  #109
RattyHHR's Avatar
Yeah I'll have to do some research on everything. I'm using the camaro steering box. Since im using a gen 1 sbc lines will be plug and play. The jeep shaft upgrade seems like it's gonna be the ticket. I need extra length and I think it's my best option.
Old Oct 26, 2017 | 02:01 PM
  #110
OleBlue
The sound track is more leaning to on the fly wedge adjustment, which in my opinion is poor.
Come into the pit and let the people from over the wall crank it in if need be.
That's what stock car racing is about.
It all started to go down hill when speed limit was 50 mph.
Then it was red light, green light to enter.
Now you have mandatory pit windows.
The day's of big blocks along with run hard and fast are done.
