HHR LS Swap Rat Rod
Old Oct 31, 2017 | 05:34 PM
  #151
RattyHHR's Avatar
One thing I'm noting about your engine... That smog era, vacuum controlled Qjet is not going to run very well without all those vacuum lines connected properly.
I'm sure you know where they all connected up and haven't made tires out of them yet...
Yeah I haven't sent them to the chipper yet. Left everything as together as I could and took pictures before disconnecting. Her dad is pretty good with these engines, he's rebuilding the carb for me today. I guess I need to look a little deeper into which vacuum port needs what so I know the essentials are connected. Thanks for the advice.
Old Oct 31, 2017 | 06:22 PM
  #152
Back in the day when that carb was just beginning to be made we tried everything to "de-smog" those things including internal mods and very little helped... I had a scrap pile of smog era Qjets at one point.
With a 305 cid a spread-bore Holly is not going to work either as they are way too big for that application (big meaning cfm). I never liked using adapter plates but a small holly with an adapter might be your only other option if you can't get the Qjet running properly.
Old Nov 1, 2017 | 01:56 PM
  #153
Cat Man HHR's Avatar
Originally Posted by Oldblue
Those intake and exhaust seals look identical to those Felpro seals.
That's because they are.
Old Nov 1, 2017 | 02:00 PM
  #154
Originally Posted by RattyHHR
From what I've been reading, the 305 will have an advantage in the gas mileage dept for a couple reasons. The smaller cubic inches of course, but the small bore makes good low end torque. So with my 3.50 rear ratio and an overdrive transmission I shouldn't be lugging in overdrive. Am I correct in my conclusion?
First gear of a 4 speed auto trans should be alright with the 3.50 rear gear, just don't go to big with a rear tire, as it will change the over all gear ratio. What trans are you going to use?
Old Nov 1, 2017 | 02:07 PM
  #155
I disagree. All you are doing is plugging off the vacuum sources for emission device's. Make sure your distributor has a ported source, not manifold vacuum.
Being it's a Q-Jet you will be using the primaries a lot. It can be jetted if need be.
Had many a GM using this carb.
Old Nov 1, 2017 | 09:39 PM
  #156
RattyHHR's Avatar
Gonna go with a 700r4. Going to a swap meet this weekend in Fresno, might get lucky out there. Also have an aluminum intake thats getting blasted right now, ill pick it up tomorrow.
Old Nov 1, 2017 | 09:43 PM
  #157
RattyHHR's Avatar
I downloaded a vacuum diagram earlier, hopefully it will help. Thanks for the advice.
Old Nov 4, 2017 | 02:58 PM
  #158
RattyHHR's Avatar
Pretty good day today. Got the engine wire wheeled and painted. Turned out great. Carburetor is rebuilt and ready to go. Working on the brackets now, will paint them tomorrow after the swap meet. Hopefully I find some good deals
Old Nov 4, 2017 | 06:06 PM
  #159
Man, that takes me back. Don't forget these
Old Nov 4, 2017 | 06:41 PM
  #160
Looking good!
