HHR LS Swap Rat Rod
Old Nov 5, 2017 | 01:58 PM
  #171
RattyHHR's Avatar
Picked up a set of ceramic coated headers at the swap meet today for $200. Not the ones I originally planned on, but I can't pass up a deal. Got a tank I'm thinking I can use for my air cleaner idea. Reckon I'll get busy.
Old Nov 5, 2017 | 03:04 PM
  #172
Cat Man HHR's Avatar
Originally Posted by Oldblue
VW I should have known that, but didn’t.
Sorry but that's not the car/engine.
It was the Chevy Corvair
http://mikescorvairparts.com/product...roducts_id=559
Old Nov 5, 2017 | 03:15 PM
  #173
Your moving forward, that's progress.
Old Nov 5, 2017 | 06:37 PM
  #174
RattyHHR's Avatar
Made some good progress on the electrical box today. Got the motor mounts painted and installed on the subframe. Cleaned up and painted a few other brackets. Coming along nicely
Old Nov 6, 2017 | 09:26 AM
  #175
RattyHHR's Avatar
So am I crazy for thinking the stock radiator will be sufficient for cooling this small block since everything is open?
Old Nov 6, 2017 | 09:50 AM
  #176
Yes! Get a larger rad
Old Nov 6, 2017 | 10:05 AM
  #177
You are indeed crazy thinking that a stock HHR rad would work. The heat transfer is barely enough for 4 cylinders.
I am no physicist, but just eyeballing the difference I can tell.
Are you planning to change the fuel delivery system? I'm not sure how a carb is going to handle fairly high pressure no return.
Old Nov 6, 2017 | 10:16 AM
  #178
RattyHHR's Avatar
My reasoning was radiator size, and ability to dissipate heat. A sbc in an enclosed engine compartment with exhaust manifolds requires x amount of radiator to cool. That same small block sitting in the open air with headers is much mire efficient at dissipating heat. The factory core in the radiator for my 305 in a 78 Chevy pickup measures 26"x17"x1.25". The HHR radiator measures 22"x18"x1". I assume 30 years of radiator technology would give the newer radiator better efficiency. My plan is to buy a new aluminum radiator from summit for about $150, and use the electric fan from the HHR. Figured I would get some opinions
Old Nov 6, 2017 | 10:19 AM
  #179
RattyHHR's Avatar
I'm gonna run a fuel cell. I'll use the mechanical fuel pump on the engine to run this carb. 40psi would probably blow the top off the carb Im keeping all my fuel system components for when I do upgrade to fuel injection.
Old Nov 6, 2017 | 10:25 AM
  #180
Not so much the size of the radiator but it's capacity. And if you go with a larger surface area/capacity radiator, you'll probably need something better than the HHR's fan.
