Hhr ss fuel line
Old Jul 5, 2021 | 02:12 PM
MagicSpoolBus08's Avatar
Hhr ss fuel line
So my fuel line ruptured and I’m having a hard time matching part numbers. Can someone tell me which fuel line number I need to look for? I’ve been looking for over an hour and I’m getting confused and none of the parts stores have them locally. Thank you.
looking at the braided kit from as tubes.
Old Jul 5, 2021 | 02:27 PM
Part #1 is the fuel line. Part number 15283296.
#2 and #17 are EVAP.
Old Jul 5, 2021 | 02:29 PM
Do you know if this would work?
Old Jul 5, 2021 | 02:30 PM
Old Jul 5, 2021 | 02:38 PM
#1 and #2 seem to be the same on all HHRs. So yes.
Old Jul 5, 2021 | 02:47 PM
#17 is only on the 2.0, so you'll reuse that. Probably not in the kit.
Old Jul 5, 2021 | 02:55 PM
I believe #17 is the fuel pipe going to the HPFP .
the braided lines will work. Plastic nylon fuel lies will also do the job
https://www.chevyhhr.net/forums/how-...follies-62310/
Old Jul 5, 2021 | 04:05 PM
It's a plastic EVAP line that plugs into the intake manifold.
Old Jul 5, 2021 | 06:08 PM
Oh, yes that plastic EVAP line, thank you , RJ
I think the braided lines would be a problem because of the diameter, possibly won’t fit into the fuel line brackets
Old Jul 6, 2021 | 09:00 AM
So the braided lines are not compatible according to the company.
And no local parts store can order them.
AND I’m still in need of fuel lines.
