dead battery
Old 08-30-2018, 05:02 PM
kustom's Avatar
dead battery
how to charge it ?
back door will not open with a dead battery ?
can i put a charger on the post under hood ?
been away a whille so i known it will be dead
any tips
thanks
kustom is offline
Old 08-30-2018, 05:07 PM
Silverfox's Avatar
Yes ... Just be sure you hook it up correctly.
Silverfox is offline
Old 08-30-2018, 06:11 PM
Charger connected to the front positive terminal on the fuse box, then the ground to the stud on the shock tower
Oldblue is offline
Old 08-30-2018, 08:37 PM
Silverfox's Avatar
Thanks Steve for finishing my reply ... I had to leave suddenly and did not have a chance to add the details.
Silverfox
Old 08-30-2018, 10:14 PM
kustom's Avatar
ok thanks
i parked it pulled in thinking i could jump it from back end
but with dead battery remote is no good
i will put a charger on a slow charge rate
thanks for the tips and help
will be back in fl. next week and get to work on this
kustom is offline
Old 08-31-2018, 07:57 AM
Ed ke6bnl's Avatar
Originally Posted by kustom
how to charge it ?
any tips
thanks
I have not done it yet but there is a small plastic piece at the bottom of the rear door that you remove to open the hatch door.
Ed ke6bnl is offline
Old 08-31-2018, 09:59 AM
kustom's Avatar
yea that sounds eazy but its a pain in the butt had to to that to a parts car
kustom is offline
Old 08-31-2018, 10:08 AM
You will be able to open the rear hatch if you attach the battery charger to the proper contacts under the hood.
whopper is offline
Old 08-31-2018, 01:34 PM
Technical Moderator
Even a 9V battery and a couple of patch cords will do the trick if you don't have a charger on hand. If you wanted to get all official; apply 9V to fuse #10 underhood fuse box, pull the fuse and stick a paper clip in the "out to switch" side.
If you want to permanently disable the tailgate put a fuse in position #11. Then the next owner will have a real headscratcher.
donbrew is offline
Old 08-31-2018, 02:02 PM
Cat Man HHR's Avatar
Don, can you say "Trick or Treat"
Cat Man HHR is offline
stowell1976
05-07-2012 03:37 AM
JJ_HHR
03-13-2010 08:51 AM
longhornss
02-27-2009 01:15 PM
Crlgrl
03-30-2008 01:57 PM
harleyfxd
09-16-2007 08:45 PM
Quick Reply: dead battery
