Higher wattage bulbs?
Old Dec 14, 2009 | 10:09 PM
LONALA's Avatar
Has anyone replaced their light bulbs with higher watts? I am thinking of installing 80/100w Hella Optilux H13/9008 bulbs. Is this okay? and would I need a wire harness for protection?
Old Dec 15, 2009 | 10:59 PM
MWG2's Avatar
Exclamation
Check your state's laws about legal wattage and light output. You don't want to get a ticket! And cops are cracking down on lights that they see are too bright.
Old Dec 16, 2009 | 01:42 AM
Comfortably Numb's Avatar
I wish they would crack down on it around here. I'm sick and tired of being blinded and having my life put in danger because of bright, and poorly aimed lights.
Higher wattage may draw too much current for the existing wiring, you could have melted wires. Why would you want it anyway? It generally translates to brighter lights and in my opinion the lights on an HHR are already too bright. I get flashed high beams a lot even though mine aren't on. Most people will not understand Wattage, Current draw, Lumens, etc. Not because they can't, it would simply require some effort which the vast majority will not do.
Old Dec 16, 2009 | 06:00 AM
gcsd3742's Avatar
I've had the HID's in mine now for almost 2 years lower wattage but brighter beams....Maybe try the HID route....
Old Dec 16, 2009 | 04:40 PM
MWG2's Avatar
Suggest these bulbs; they will give you more light but not burn the wires:
https://www.chevyhhr.net/forums/show...t=20008&page=3
mcanni
Apr 18, 2014 10:47 AM
hhrumadbruh
Mar 29, 2013 08:07 AM
hhrumadbruh
Dec 9, 2012 04:49 PM
ChevyMgr
Dec 28, 2010 09:49 AM
bugflipper
2.4L Performance Tech
21
Nov 1, 2009 06:44 PM
