Horny HHR
Horny HHR
This is a weird "problem" or small anoyance that I discovered the other day. It seems that the horn gets activated sometimes when I turn. At first I thought I was hitting the button, but I'm not. It's happened about 4 or 5 times in the 2 months I've owned it. Any ideas on what the problem might be?
Its probably something with the contacts behind the wheel at the top of the steering column that complete the circuit from the horn buttons to the rest of the vehicle. Does the horn stick "on" or is it a momentary "beep" every now and then. If its just a little unplanned "beep" I'd wait on pulling the wheel, if it sticks "on" you'll be looking at a new contact ring. On of those PIA jobs and probably best left to a tech.
