HP Tuners Question?
Old Jun 22, 2016 | 08:49 AM
2005HHRauto's Avatar
Originally Posted by drummerboy0088
Awesome - thank you for the info 2005HHRAuto!
So you're saying if you run 93 pump gas, wait until you're half full then fill up with e85 to get E47?
Yes...
8 gallons of E10 91/93 gasoline + 8 gallons of E85 = E47
The Math:
8 x E10 = 80
8 x E85 = 680
80 + 680 = 760
760 divided by 16 = 47.5 or E47.5
And we just call it E47...
It's a silmple half & half mixture, that's easy to remember
You don't have to be 'dead' accurate on this & you will might be a gallon or two off at 1st, but the ECM will take care of it.
BUT with each fill-up AFTER you 1st mix, be it full or partial, do a half & half mix.
You will know how much you need to fill-up by knowing what your gas gauge is telling you.
Each 'mark' on the gauge is appox: 2 gallons, so if your down 6 'marks' = 11 gallons total needed, 5.5 gallons of E10 91/93 gasoline + 5.5 gallons of E85
2 'marks' = 3 gallons total needed. 1.5 gallons of E10 91/93 gasoline + 1.5 gallons of E85
8 'marks' = 15 gallons total needed & you must be empty...
Remember you don't have to be 'dead' on accurate.
If I think that I need 8 gallons total I'll go to the 1st pump open, be it E10 or E85,
I'll then put in 4 gallons, then I'll go to the other pump to completely fill-up.
Maybe it will be 4, or maybe it will be 3, or maybe it will be 5.
Doesn't matter as you're close enough.
Over time you will grt real accurate, & really get to know what your gauge is telling you.
Originally Posted by Oldblue
A reference to Van Halen's " Hot for Teacher" ?
I knew I got that from somewhere...
You are sharp...
Old Jun 22, 2016 | 05:39 PM
drummerboy0088's Avatar
All good to know. There's an e85 station not too far from me. Might have to give this a try when I get HPT!
Old Jun 22, 2016 | 05:59 PM
You can do it now., no need for HPTuner..
Old Jul 11, 2016 | 02:17 PM
paperboy72's Avatar
so stock GMS1 tune you can mix half and half WITHOUT HP tune? wow didnt know that...i think i had you send me your e47 tune for HP, i just have never got a chance to mess or load it in. really bad of me... i got an HP tune suite from a past member for free and still have yet to use it
ADM PERFORMANCE
Sep 14, 2008 09:41 PM
EcoBoost
2.0L Performance Tech
133
Jul 27, 2008 11:41 AM
gcsd3742
Mar 19, 2008 09:04 PM
Lone Ranger
Feb 17, 2008 09:36 PM
BoltZ22
North Central
Oct 29, 2007 11:52 AM
