I broke the Main power lug off the engine fuse box
Old Aug 14, 2018 | 10:22 PM
hellshotrod's Avatar
iv intrchange changed them a lot u may have to move some fuses or relays but they work the same , lmk thanks dave
Old Aug 15, 2018 | 12:21 PM
DaveB's Avatar
I drove it about 5 miles when I test drove it, no problems. My daughter lives 3 miles from me and she drove it home, no problems. She took her kids to school, called and said it doing the same thing...Again! Still running with the repaired fuse box.
Grounds? Battery? Which should I check?
Old Aug 15, 2018 | 12:57 PM
Both. Sounds like something that is subject to vibration, or you never checked the battery (it shouid be at least 12.46 volts).
Old Aug 21, 2018 | 02:35 PM
DaveB's Avatar
OK, I took the car to Advance and had them run battery and charging test. I checked the battery with MM, static it was 12.12v, drove three miles to AA their test printout was 12.52v.
Approx. 3 mi to AA and back 3 mi. no problem and no lock cycling. I guess it doesn't surprise me there were no problems found.
I did replace the alternator with AA supplied one a few months ago. Does anyone think that could be problem?
Any suggestions for Ground locations?
Old Aug 21, 2018 | 03:02 PM
12.12 volts is low. Could cause electrical "gremlins" to pop up.
12.52 is marginal.
Fully charged is usually 12.7-12.9 range.
You should get them to load test the battery.
Old Aug 21, 2018 | 05:28 PM
My last battery was pronounced dead at 12.51 volts, it had a dead cell.
Truckette
"How To" Tutorial Library
7
Aug 31, 2020 09:37 PM
Bruno Agostini
Apr 27, 2018 08:35 AM
menance
Dec 22, 2010 06:14 PM
Melodale
Sep 13, 2009 06:14 PM
Lee3333
Feb 1, 2006 07:48 AM
