I have an 06 LT
Old Mar 27, 2008 | 11:51 AM
hells_hot_rod's Avatar
Originally Posted by oneton
They are not that fast but don't be scared to let the RPM turn up. Yes your MPG will drop a little but let the ECU learn what you want and you will find it a little better
[The block learn cell in ECU]
Thanks....i took the time to figure out just what you had said here since i haven't dealt with ECU's or ever understood what block learning meant.
so basically, without any mod, the harder i push it the more it learns the values appropriate for the cells it references while being in that environment? thus over time expeirencing better performance, due to those cell values?
Old Mar 27, 2008 | 05:35 PM
ProjectX's Avatar
i do actually like the little power that the hhr does have, i actually like cruising it, for once i don't have a desire to drive like a speed demon, haha. i will be adding the usual tho, intake and exhaust.
