Is this insert removeable?
Old Nov 3, 2007 | 04:52 PM
fastED's Avatar
I started to paint the front bumper center/lower insert today, and discovered that it is actually a separate part, not just a (black) painted section of the front bumper. Is that black insert removeable, or should I just mask everything off, and paint it in place? I sure would like to remove it and paint it in the house, if possible.
Old Nov 3, 2007 | 04:59 PM
Yes it is but I believe you have to remove the bumper to remove it.
Old Nov 3, 2007 | 05:17 PM
mizzouHHR's Avatar
If you live in a state that requires a front license plate, then the bracket that holds your plate is riveted to your bumper through that black piece.
Old Nov 3, 2007 | 10:29 PM
Dan's HHR's Avatar
Ask to a body shop or dealer to avoid breaking it,it's wiser to ask it for it instead of repair it
Old Nov 3, 2007 | 11:25 PM
bigallis1's Avatar
Ed, the insert is removable as Mike had indicated. You have to remove the front bumper to get at the insert. It is held on with some kind of clips.
Do a search on here for bumper removal, I think Mike from SoCalHHR's did a step-by step removal procedure for it.
I would recommend a good plastic/vinyl primer before painting. This is recommended by my paint supplier. And it does help with the bonding.
Good luck and let us know how you make out?
Old Nov 3, 2007 | 11:32 PM
I'd check with a body shop that work's with a Chevy dealer. One by my house did Bonnie's and it was very reasonable. Sorry, don't remember how much but it was less than $100.
Old Nov 4, 2007 | 10:13 AM
gravett1's Avatar
Why did they make them black anyway?
Old Nov 4, 2007 | 10:33 AM
Black Rose's Avatar
Black is the one colour that compliments all other colours. It's probably also cheaper to produce black plastic.
Old Nov 4, 2007 | 10:37 AM
Memphis_HHR's Avatar
Holes
My 07 has the holes in the bumper cover itself and not the black plastic. I chose not to mount the license plate holder. The holes are small indentions in the bumper cover and not punched all the way through.
Cat Man HHR
14
Apr 27, 2015 07:25 PM
Mercury
Oct 29, 2013 04:26 PM
Tofastgt
Mar 3, 2013 06:54 PM
Lowgearjoe
15
Sep 28, 2010 05:11 PM
