Installed the Rear Anti-Sway bar tonight
Old Jun 9, 2007 | 08:21 AM
Goose's Avatar
Thanks for the pics bigallis1! I've been talking to Brad at neverenoughauto and will be ordering mine on Monday I mentioned that he should stop by here as we have a few folks who may be interested in ordering the sway bar. He said he would check us out as they are looking to add another site as being a supporting vendor.
You need a torque wrench to do this right? 45 lbs if I remember correctly?
Goose
Old Jun 9, 2007 | 09:30 AM
courthousedeb's Avatar
Yes Goose...it's 45 lbs.
I've got install pictures from Mike at SoCal that he had posted on his site that he has allowed me to use for a how to. I'll post them in that section if they are not already there...along with my Deb How-To.
Old Jun 9, 2007 | 09:52 AM
Black Rose's Avatar
Originally Posted by GDZHHR
WOW!!
I'm not doubting or slamming but its only 4 bolts. Took me about ten minutes. I think most here who've done it were about the same. All you should have had to do was crawl under and bolt it up. With the ramps it should have been a breaze.
Took me about an hour as well, mainly because one of the bolts did not want to go into the plate properly. I ended up having to swap bolts around in order for it to install properly.
That was also the first time I had been under a vehicle in over 20 years, so I spent some time checking out the undercarriage
Old Jun 9, 2007 | 09:54 AM
Was looking thru all my many HHR photos and found the pics that Mike from SoCalHHR's had for install.
Thought I'd share them with those of you who would like to see them and post my version of installing the sway bar.
Plus the pics are here on the site, just in case Mike's page ever disappears for some reason.
This is what your package should look like if's it's a Progress Tech.
Very large heavy box with sway bar and a bag of parts.
Mine came with instructions when I bought it from Mike.
Hardware needed to install the sway bar.
(oh lookie there...there's the directions inside that plastic bag)
Ladies will read them...guys will do the macho thing and set them aside.
Henry and I backed my car up on ramps and that made it much easier to install.
It is recommended to do it flat...
but when you are in your early 50's like us,
you don't fit under the car like you used to.
Easy part is finding the holes where the sway bar will attach.
Then slide the piece that the bolts will screw into above these holes
and line it up as best you can.
This can be a little tricky when putting the bolt and washer on,
cuz the dang thing moves.
Insert bolts and hand tighten.
Tighten the right side with torque wrench to 45 ft lbs.
Tighten the left side with torque wrench to 45 ft lbs.
You are now done...take that mean machine of yours out for a spin
and check out the difference in the ride.
Thanks go out to Mike from SoCalHHR's for the great photos and product he supplied me.
Definitely made a huge difference with body roll once it was installed.
Old Jun 9, 2007 | 09:56 AM
Black Rose's Avatar
Only thing different I did from Mike's was added Loctite (Blue) to the bolt threads.
Old Jun 9, 2007 | 10:10 AM
Lone Ranger's Avatar
Does this bar help an HHR that has the standard soft ride suspension?
Old Jun 9, 2007 | 10:14 AM
If you're talking about the stock suspension and not what comes on the 2LT, yes it does. I've got a 1LT and it definitely improved the ride...better cornering and less body roll on the highways in the wind. Definitely an inexpensive mod that I would recommend to any HHR owner.
Old Jun 9, 2007 | 11:01 AM
nfboy's Avatar
Goose
That is where I got mine. Great company to deal with. The sad part is I just have not gotten around to putting ot on yet. Bad me.
Old Jun 9, 2007 | 11:06 AM
Shame on you nfboy...you need to get out there and pop that baby on. I noticed we haven't seen bigallis today...must be out there enjoying his new sway bar.
Old Jun 9, 2007 | 12:30 PM
Alzonie's Avatar
When I installed mine I didn't have a torque wrench, so I just put lock-tite on the bolts and tightened them as much as I could. I figured you can't make them any tighter than tight! What exactly is the need to use a torque wrench in this instance anyway.
