Interesting gas mileage observation
Here's the story, I don't quite know what to conclude of it yet...
Bought my HHR 2 months ago; as of the start of this week, it had ~ 4200 Km on the Odo. With my usual daily commute, and after the winter to summer gas switchover, I used to get a very consistent 8 l/100 (29.4mpg).
On Monday, I drove to Montreal and back (~500 Km) towing a small trailer. I took it easy, never really exceeded 105 Km/h. The trailer was empty for half of the trip, and on the way back I estimate that I was pulling a total weight of about 750 pounds, trailer included. I could feel the constant pull / drag from the trailer, but nothing unexpected. I got 8.3 l/100 (28 mpg) for that trip.
Now the surprising part: I refueled after the trip and reset the DIC; it's now estimating my daily commute at 7.3 l/100 (32.2 mpg). I still need to run a bit more gas through it to be sure, but I definitely see a trend down.
My hypothesis so far are:
1) I got a really good batch of gas
2) By towing the trailer for 500 Km, I sped up the "breaking in" on the engine and I'm getting the mileage of a 10000 Km engine.
3) I'm out of my mind and my next fillup will be back to 8 l/100.
The interesting part is that I can rule out 1 & 3 with time. I'll report back in a couple of weeks. I'm also changing the oil to synthetic next week, just in case the "breaking in" hypothesis verifies....
Any other explainations ???
Yves
Yves
The calculation jumps around quit a bit. For example, if do a round trip to the Kanata Costco via Hwy 416 & 417, I'll see around 9.2L/100km by the time I get home. If I do a round trip taking the streets, I end up with about 10.3, simply because of all the stop and go.
It's probably due to the average speed being raised by the trip to Montreal and back. The L/100km number will come down again over time as your average speed drops from local driving. Doing a highway run also certainly didn't hurt.
On the flip side, you are also at the mileage point where I noticed my mileage started to pick up. By about 11,000 kms it will take another little jump.
No, no, I reset before the Montreal trip, and then again after my Tuesday morning fillup, so the Montreal trip has no impact. As expected, it moved quite a bit on Tuesday, less so yesterday, and today it looks to have settled at 7.3, all with my same typical daily commute (it hardly varies, and these numbers include some idling in traffic at the bridge), which is why I'm kind of stumped. (My current fuel range estimate + trip since fillup is > 850 Km)
I'm thinking that I may have finished breaking in my engine in a very short time. There has to be a reason that they tell you NOT to tow anything for the first 1000 miles...
I agree though, it's a bit too soon to conclude, and it may end up moving up a bit with the weekend shopping, but there's something there. I have a keen eye for these things. The car that I traded in for the HHR had a slipping clutch (not my doing!); I could bet you that nobody finds out about it for another year.
Yves
Yves
I don't trust the DIC - even with reset after each fill.
Measuring MPG the old fashion way is not totally error-free either, unless you average over about 10 fillups.
Yves
Yves
Yves
I will admit I think I failed the metric system in school, but you did the conversion for me in your post but I am still confused how it could be going down
Snip... With my usual daily commute, and after the winter to summer gas switchover, I used to get a very consistent 8 l/100 (29.4mpg).
Now the surprising part: I refueled after the trip and reset the DIC; it's now estimating my daily commute at 7.3 l/100 (32.2 mpg). I still need to run a bit more gas through it to be sure, but I definitely see a trend down. Snip...
Yves
Yves
My DIC only predicts DISTANCE (miles to next fill up)
It must gain something in the metric conversion
And whats with this l/100Km ?
Isn't that bacward thinking where less is more
Yeah, it's down with the metric system (gas consumed per fixed distance), vs up with the english system (distance travelled per fixed gas volume).
To add to the confusion, imperial gallons (formerly used in Canada) are 20% larger than US gallons. So we get 20% better mileage.
Yves
Yves
Never thought of it that way
