Interior trim material
Old Jun 21, 2019 | 11:01 AM
speedwagen's Avatar
Some plastic parts have a recycle graphic that identifies the type of plastic.
ABS is a common plastic used on interior trim pieces.
As stated in a previous post, the locktite epoxy for plastic would be a good choice.
​​​​​​​I have used it successfully on structural plastic repairs.
On a side not about chemicals and plastics--never use locktite type (anerobic)thread locker around polycarbonate palstic.
It will cause the plastic to crumble in a few days.
Old Jun 21, 2019 | 02:13 PM
Consider heat welding. ABS and plastics turn to glue when melted.
Old Jun 21, 2019 | 02:52 PM
Cat Man HHR's Avatar
Hmm. If you want a permanent bond then you SHOULD worry about how clean it is.
The key to a bonding agent is to have good prepped and clean surfaces.
Thank you for your support.
hvrod
Dec 29, 2009 01:22 AM
Rcflyboy
Oct 5, 2008 07:13 PM
masterchief1112
Sep 9, 2008 09:07 PM
TexasT
Apr 4, 2008 04:44 PM
Snoopy
Oct 5, 2006 12:01 PM
