Intermittent headlight issues
Old 03-15-2019, 06:37 PM
092lt's Avatar
I had the driverside headlight burn out, so I thought, about 3 months ago and I replaced both lights at that time. The drivers sides light went out again so I replaced the set again. The drivers side light went out a 3rd time and the parts store took the lights back and exchanged them for me this time. I checked the harness and all the wiring when I replaced the bulbs the last time and everything seemed fine. This time when the drivers side went out again I said screw it. Both high and low beam were out. I made it about 10 miles down the road and the light popped back on. I was pulled over by a cop the other day when I lost my headlight again and when the officer told me I was pulled over for the light it popped back on again. When I got home I went through the wiring again to make sure all was good and the contacts were clean but I didn't see any issues. This is still happening often and I can't figure out the problem. Has anyone else had an issue like this?
092lt is offline
Old 03-15-2019, 06:41 PM
Check for loose ground wires, loose fuses and relays in the underhood fuse box
Oldblue is offline
Old 03-15-2019, 06:43 PM
092lt's Avatar
I forgot to ask where the ground was located for the headlights
092lt is offline
Old 03-15-2019, 07:01 PM
Oldblue is offline
Old 03-15-2019, 07:16 PM
092lt's Avatar
Sorry to be dense but where in there is the headlights? I'm not understanding all the codes
092lt is offline
Old 03-15-2019, 07:27 PM
This should help
G109 and G111and G201
Oldblue is offline
Old 03-15-2019, 07:32 PM
092lt's Avatar
This should help
Thank you that helps. I will have to look and see
092lt is offline
Old 03-15-2019, 07:33 PM
Driver side headlight grounds at G109. Passenger side grounds at G111.
Do the DRL work? If they do then it is not the ground it is the connector.
donbrew is offline
Old 03-15-2019, 07:37 PM
Oldblue is offline
Old 03-15-2019, 07:39 PM
092lt's Avatar
Do the DRL work? This is a time that the year makes a difference.
However, if the bulbs were not blown out it must be either the wires or the connector
I never really checked to see if the the DRL went out or not. I've never though to check during the day. I've had light issues with other chevy and it was always a burned out connector. This time it's not so I would think if it's wiring it may be a ground issue
092lt is offline
Quick Reply: Intermittent headlight issues
