Jump starting other vehicles?
Yeah, I figured that was it since I could never get the green light. Just can't figure out why. I tried the marked ground point as well as other obvious ground points like bolts. Not a big deal. I got it figured out. Just wondered if anyone else had ever had the same situation.
Ok back to your problem... is there a bare stud/bolt on the radiator support... on the engine side... under a slight lip... hard to see if you are looking straight down... infront of the coil cover about 6 or 8 inches... it s on my 2006 and seems to be a good ground.
if you put the ground cable on the stud at the back of the fuse box... you will get a spark... a big spark... and then you steering won t work
