Key fob
Took key fobs apart and checked for loose battery clips both were ok. Cleaned the push pads and contacts. Checked for voltage across the contacts and both had battery voltage. Reassemble the fobs and only the horn button worked. Took fobs apart and tried shorting across the contacts with foil on the end of a eraser and all worked except the remote start. Glued small circles of foil to the push pad contact spots and reassemble the fobs. All fuctions now work including the remote start.
There or many other places like eBay. Any place that carries the Dorman line can get them if Ebay is too scary.
https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
You might have to go deep for a panel set. https://www.ebay.com/itm/Keyless-Ent...MAAOSwxwNZ4rqV
https://www.ebay.com/itm/15114376-15...frcectupt=true
If you can only find one with the trunk button it will work. Or for that matter send me $10 by paypal and I will send you 2 used fob cases and 1 circuit board. They don't have Remote start, but Panic+Lock does the same thing.
The circuit boards have all 7 button positions provisioned.
FWIW I just got a couple of key fobs from this place, https://www.keylessentryremotefob.co...Fob-s/5515.htm
They also sell the case and rubber PB's
