Lowering Kits
Old Feb 13, 2008 | 05:59 PM
deebo187's Avatar
Lowering Kits
I want to lower my 2006 HHR and there are a lot of kits available. Is there one or two kits to stay away from? I am thinking about going to 18 inch tires and wheels, will lowering make the rear rub with this setup.
Old Feb 13, 2008 | 06:21 PM
A response I got from Jeff at Truckshop can answer your question on 18's, lowering, and rubbing:
Originally Posted by TruckSHOP.com
My thought on the tires is that a 235/40/18. Usually those are recommended for 8 inch wheel or greater for width. It will fit on the 7.5 rim. If you've lowered it a lot (I mean really slammed) you might need to trim just a little due to the extra width, but it isn't much.
That 235/40/18 is just about as close to stock diameter you can get. I usually put a 225/40/18 on a slammed HHR, or if you are stock height or dropped an inch or so you can roll on a 225/45/18 for a bit more sidewall. So it depends on how your suspension is going to be set.
The 235/40/18 is 25.4 overall, 225/40/18 is 25, and the 225/45/18 is 26 overall diameter. Stock 16 inch tire is 25.3 and the stock 17 inch is 25.5.... so in all cases speedo difference would only be 2-3% maximum.
Jeff
AJochum
98
Jan 19, 2020 10:35 PM
lgn6969
Jul 5, 2012 01:40 PM
Doc.Smith2011
May 10, 2011 12:53 AM
deebo187
Feb 14, 2008 05:41 PM
deebo187
Feb 14, 2008 03:06 PM
