Mechanics says I need new catalytic converter
Old May 13, 2025 | 04:09 PM
Dave1972's Avatar
My car has a P0451 code which is related to fuel pressure. I took it to get it looked at to see what it would cost and they said, I need a new catalytic converter. But they have a hard time finding that part, however I didn't think that code had anything to do with it. Is he trying to rip me off?
Old May 13, 2025 | 04:26 PM
P0451 is the fuel tank pressure sensor acting up. not the fuel pump. It is a drop the tank unscrew the sensor repair. Could be frayed wires shorting.
Yes, if that is the only symptom run away. Unless AZ suddenly went al CAL on emissions I don't know why sourcing a cat would be a problem. They are available on ebay.
Old May 14, 2025 | 06:45 AM
PulpFriction's Avatar
I would ask more questions about why they think it needs a cat. The P0451 is certainly no basis for that. It’s a problem with the fuel pressure sensor. Is that the only code? Are there any symptoms? What are they?
keep the original cat if it all possible. Replacing it unnecessarily is a big mistake.
Old May 14, 2025 | 11:12 AM
Dave1972's Avatar
it doesn't really have any symptoms.Besides the light, and that is the only code
Old May 14, 2025 | 02:51 PM
Not that expensive and fairly easy to change
https://www.rockauto.com/en/catalog/...re+sensor,6385
You don’t have to completely drop the fuel tank
ETHAYES83
Oct 30, 2024 11:25 AM
cj-five
Drivetrain (Excluding Engine)
Sep 21, 2024 09:59 PM
Jessicasdd
Jan 31, 2022 08:54 AM
domenick_2010HHR
2.2L Performance Tech
10
Jan 25, 2018 01:41 PM
jbman
May 19, 2011 10:53 AM
