Need oil cooler for 2.4L
Old May 24, 2024 | 03:42 PM
Redfred's Avatar
Can anyone direct me to were I can purchase a New oil cooler for a 2006 2.4 ?
Old May 24, 2024 | 03:52 PM
EBay for a used one.
Old May 24, 2024 | 07:59 PM
The LNF 2.0 turbocharged part number, both Autozone and O'Reilly say it does not fit the 2006 2.4.
Old May 24, 2024 | 08:08 PM
How could it get damaged? I can't imagine it getting damaged short of using a hammer.
If it is leaking oil the O-rings can be replaced.
It is not a vital part; you could block it off. A junkyard should have a 2006 2.4.
Old May 24, 2024 | 09:21 PM
12594525 is the (discontinued) Part Number for the 2.4.
Old May 25, 2024 | 05:19 AM
I searched all my sources, no new ones available, they are common to the same year Saturn, Cobalt, G5
contact your local pick a part
Old May 26, 2024 | 09:56 AM
PulpFriction's Avatar
You probably don't really need an oil cooler for that car.
Old May 26, 2024 | 10:04 AM
Well if it’s rusted out and leak oil or coolant, yes you have to replace it. Somebody on here used an adapter plate and external oil cooler. There are companies that use the Ecotec with oil cooler, but they don’t seem to be online any more.
it might just be the oil seals need replacing.
Old May 26, 2024 | 10:12 AM
Redfred's Avatar
… I replaced the seals and still leaking. Removed again and pressure tested and has a split.. thanks anyway. Fred Maio.
Old May 26, 2024 | 10:14 AM
Redfred's Avatar
It split .. no LKQ will sell separate from engine
