New member with a/c problems 2009 2.4L
Old Mar 16, 2024 | 07:30 AM
I’ve moved and merged your threads . Sorry for any confusion
Old Mar 16, 2024 | 09:34 AM
Why would you take a car over 15 years old to a dealership, for other than recalls? They don't know anything the guy down the street doesn't, maybe less. Dealer mechanics only know how to replace parts, they struggle with proper diagnosis.
Old Mar 16, 2024 | 09:40 AM
Sometimes you have to look at the details, I’ve seen some ac systems simply over charged causing problems.
Old Mar 16, 2024 | 11:27 AM
Based on his previous post stating that he put in less than a can of refrigerant, I would say it is undercharged. R134a comes in 12 oz cans. The HHR system takes 14 oz. High side pressure should be over 200. He said his was 180.
Old Mar 16, 2024 | 03:01 PM
There see, FMG has experience with these things.
Old Mar 17, 2024 | 11:23 AM
denhamhhr's Avatar
I know the dealership was a bad idea, just hoping already tried multiple locale resources. Still no success.
Old Mar 17, 2024 | 11:24 AM
denhamhhr's Avatar
Will put the gauges back on it and try adding more.
Old Mar 17, 2024 | 11:58 AM
Since you replaced the compressor and pulled vacuum , did you put some compressor oil back in with the Freon ?
Old Mar 17, 2024 | 12:29 PM
denhamhhr's Avatar
Yes,, I did an oil charge. When I jump the relay, runs great. Temp coming out of the vents 40 degrees F, with the outside air temp 82 degrees F. I do appreciate everyone's advice. Thanks!
Old Mar 17, 2024 | 09:00 PM
greg8453's Avatar
Need to get a read of the module and see why it's not grounding the relay. Do you have a scan tool that can read the datastream?
