newer doors on older model
Old Sep 8, 2019 | 08:26 PM
bowtieboy68's Avatar
Admins: I wasn't sure what forum to put this question in.
I recently found a pair of rust free doors from a 2011 (passenger front and drivers rear).
My 2007 has the power window controls at the bottom of the "waterfall" and power mirror controls are in drivers door.
The 2011 front door has the window control mounted to it. Obviously, I will be using the interior panels from my 07, to delete the switch from the door. but what is involved in altering the front door to be controlled by the waterfall switch?
Thanks in advance.
Old Sep 8, 2019 | 08:47 PM
Sheet metal of the doors are gonna be the same. When swapping the inner panels any other different parts, if there are any, could be swapped as well. Wiring would all still be from the 2007, locks and window motors are probably all the same across all years. If not you've got the 2007 parts.
Old Sep 8, 2019 | 08:59 PM
Transfer the wiring. There may be different panel mount points between years. I believe the conduit attaches to the body, unplug it and switch it
Old Sep 9, 2019 | 08:59 AM
The wires inside the driver door need to be swapped , the older inner door panel can be used but you will need to modify it .
I would look at using the new inner door panel, so you’ll have a set of dummy switches in the arm rest.
Old Sep 10, 2019 | 11:07 AM
hellshotrod's Avatar
u can change out the doors , the only thing i have had to do is swap the wiring in the door its self and change the small metal bracket the the arm rest of the panel bolts too as its in a different place most doors iv done have the sqr holes off set and u just move the clips for the screws , with that said i have had too make a pattern from the old door and make new holes on some of the later doors ,good luck its a easy swap ,
Old Sep 10, 2019 | 11:50 AM
hellshotrod - you are the best man. Big thanks for your post here and so many others.
Old Sep 10, 2019 | 09:30 PM
thanks whopper , i,m not the best just try my best to help others and be honest , at 55 soon i don't have as much time to care for others and help but i will try to the end ,,,,dave and crystal care!!!!
KYWes55
Jul 30, 2019 08:35 AM
kustom
Jun 28, 2018 09:31 AM
Vinnie_Madrox
Aug 23, 2016 07:56 PM
Doctor Who
May 31, 2015 11:27 AM
2007HHRLT
Dec 11, 2013 04:29 PM
