No ac ,no blower
Old Mar 28, 2012 | 03:13 PM
elbeau54's Avatar
a/c not working
engine lite came on code said to chg thermostat,i did,cleared codes. ran fine for about a week now the a/c will not start . clutch fuse ok swapped around but clutch on compressor not engaging.
Old Mar 28, 2012 | 04:44 PM
to the forum elbeau54!
You're not afraid to dive right in, that's good!
What code number did it set if you can recall, because I'm thinking you may also have a bad temperature sensor, that will keep the compressor from engaging.
Old Oct 25, 2021 | 04:02 PM
elbeau54's Avatar
No ac ,no blower
Car has been sitting about 2weeks in garage. Tried ac and it wouldn’t come on or blower motor. Water was dripping from under blower . I don’t believe the cooling fan on motor came on so I’m thinking it’s all related . Please any thoughts. Thanks
Old Oct 25, 2021 | 04:07 PM
Engine running? Is the check engine light in? Is the coolant system full?
Old Oct 25, 2021 | 04:24 PM
Gearhead1's Avatar
Think might be talking about hvac fan
Old Oct 25, 2021 | 04:25 PM
What was wrong the last time the AC was broken ? (you ask for help then but never came back )
I suggest you revisit whatever was repaired back then.
Old Oct 25, 2021 | 05:02 PM
Threads merged
Old Oct 25, 2021 | 06:52 PM
We’re concerned with a problem from 2012? 9 years ago? Possibly causing the AC to stop working?
Let’s investigate from the present, as I asked in post #4
Old Nov 19, 2021 | 02:12 PM
elbeau54's Avatar
Interior fan not working,still
After changing the resistor ,new fan and checking all the fuses fan still will not come on. After checking with meter at wire input to fan didn’t get any power reading. Wondering if fan controls on dash could be bad . Thought s?
Old Nov 19, 2021 | 03:02 PM
Yes the HVAC controls could be the problem. Along with the resister fried by water , a bad ground wire , the fan motor toasted by water damage. Fuses and relays are also suspect. All must be investigated and tested .
