Washing the car
Old 06-08-2018, 09:46 AM
Cat Man HHR's Avatar
Washing the car
Hi
Tried this experiment and worked alright.
Used Turtle wax Zip wax:
http://www.turtlewax.com/our-product...x-car-wash-wax
Bought a sprayed nozzle from Harbor Freight:
https://www.harborfreight.com/car-wa...zle-60773.html
Bought an inline RV water filter from Walmart:
https://www.walmart.com/ip/Camco-Wat...-Hose/14504321
The reason I did this is because I use to use just the Turtle wax soap with just water from the house, which is soft water, but still had impurities(?) in it and left water spots on the car that you could see in the glass.
I did this on a cloudy day. Did not use a towel to dry it off and wasn't bad.
Going to have to try a soap like this to see if I get better results:
https://www.rainx.com/product/washes.../#.WxqWaEgvwdU
Thanks
Cat Man HHR is offline
Old 06-08-2018, 10:31 AM
ICT_GG's Avatar
I used to have a "Mr. Clean" spray system that had an in-line replaceable filter. Those filters do make a difference. Also have a large drying "squeegee" that works great on flat surfaces. Use a leaf blower on the rims and around the mirrors and anywhere else water hides out.
ICT_GG is offline
Old 06-08-2018, 01:18 PM
Don't have a leaf blower.
I wanted to try a dryless soap/water thing. The Turtle wax product does state it's a dryless product but doesn't hold up to it's statement.
Old 06-08-2018, 08:39 PM
In summer I use a California Duster, Maguiar’s detailer and if required
Maguiar’s spray wax. No water required
Oldblue is offline
Old 06-08-2018, 09:13 PM
I use a California Duster as well, & my old one I use on my Zero Turn mower, after I blow it off with leaf blower. And it gets a wax job end of each mow season. (seriously)..
sleeper is offline
Old 06-09-2018, 04:34 AM
Ron S's Avatar
To wash ours I use a "Foam Canon", it hooks on the end of my power washer head and puts a layer of soap foam over the car, I use Maguire soap, then a I use the power washer with a spread nozzle to spray the cars off. It works well. There are some YouTube videos of it in use. Neat gadget. My power washer is electric.
Ron S is offline
Old 06-09-2018, 10:54 AM
Technical Moderator
Be careful with power washers if your car has pin stripes!
donbrew is offline
Old 06-09-2018, 10:56 AM
Ron is what you do is a wash/rinse but not dry method?
Old 06-10-2018, 06:32 AM
Ron S's Avatar
I wipe them down with microfiber cloths.
Ron S is offline
Old 06-10-2018, 09:28 AM
"Stupid is what stupid does"
Just saw large size towels at Home Depot
https://www.homedepot.com/p/HDX-Micr...-516/203837988
Quick Reply: Washing the car
