O2 Sensor readings?
Old Jun 1, 2014 | 01:54 PM
O2 Sensor readings?
I need someone to verify the O2 sensor voltage readings on a 2009-2011 2.2 L.
At idle after warm up what is the #2 sensor reading? Also, what is it engine off ignition on? And the peak #1 sensor reading?
I'm trying to figure out if mine is faulty or if I really do need a new cat.
Any experiences with the Made in Canada cats as seen on Ebay for $189?
Old Jun 2, 2014 | 05:32 PM
My concern here is that I have replaced both O2 sensors, the #2 twice. The cheap #2 sensor was causing a "stuck lean" code, the NGK is now causing a P0420. But I have a cheap #1 installed.
#1 peaks at about .800 Volts and #2 (NGK) reads about .75 Volts, the cheap #2 read about .2 Volts.
I need baseline numbers from a healthy 2.2L HHR. I know I probably need a new cat, but I want to be sure what caused the failure.
Old Jun 3, 2014 | 06:07 AM
Come on, I seem to remember a lot of talk about people getting Bluetooth OBD readers.
Old Jun 3, 2014 | 07:56 AM
Would love to help you out, but I have an SS.
I have the torque app with the Bluetooth wireless reader. Can I get those readings with this?
Remember donbrew, I'm a computer dummy, so be nice with your answer.
Old Jun 3, 2014 | 08:43 AM
Maybe with paid version. If you have android ScanMaster Lite is available at PlayStore for free, it will.
Old Jun 3, 2014 | 08:47 AM
Don I can vouch for the cat off E-bay, I put one on after the flex pipe broke back in April, fit prefect, no rattles code issues, I still have my factory O2 sensors in my '07
so I don't know if those numbers would help, and I don't have an OBDII reader
Old Jun 7, 2014 | 05:35 PM
Correction: I can't find an app for the android that does it.
donbrew
Aug 30, 2014 05:36 PM
gulfcoastal
Nov 8, 2013 07:12 AM
OVRBOOST
2.0L Performance Tech
12
Apr 1, 2011 01:20 PM
old man
Nov 28, 2009 10:30 PM
ZTony8
Jul 24, 2009 05:27 PM
