Oil pump question
Old Apr 16, 2017 | 07:55 PM
hurst2001's Avatar
Oil pump question
I was looking at a 2.2 pump I see a spring and the unit sits in the cover .. so how does it work to pump ...
Old Apr 16, 2017 | 07:58 PM
That is the oil pressure relief valve. The pump is part of the chain cover.
Ecotec Front Cover W/Oil Pump 12637040
Old Apr 16, 2017 | 08:37 PM
hurst2001's Avatar
So is it driven by the. Chain to pump like the old style engines ?
Old Apr 16, 2017 | 10:20 PM
The crankshaft
Old Apr 17, 2017 | 06:55 AM
The crank balancer engages the the pump from the crankshaft.
Old Apr 18, 2017 | 08:28 PM
hurst2001's Avatar
Thanks guys well balance shaft chain was stretch bent a sprocket tooth the tensioner in side the motor was shot or gave out .. causing no flow from the pump but like I said she old and ready for retirement ..
Oldblue
Maintenance and Upkeep
Nov 29, 2016 08:19 AM
malcolmjason
May 14, 2015 02:30 PM
bartSS
Jan 20, 2010 01:25 PM
Hotrodbob
Oct 2, 2007 11:20 PM
EL_REY
2.4L Performance Tech
14
Aug 28, 2006 06:53 AM
