Oxygen Sensor Codes P0138 and P2270
Old Dec 27, 2019 | 06:15 AM
cturboaddict's Avatar
Wife said the CEL came on today. Pulled Codes P0138 HO2S Circuit High Voltage Sensor 2 and P2270 HO2S Signal Stuck Lean Sensor 2.
Any thoughts?
And which one is sensor 2? I've replaced the one closest to the motor a while back. Is sensor 2 the one further down under the car?
Old Dec 27, 2019 | 08:02 AM
That’s correct the second one from the engine is the #2 O2 sensor
P0138 would indicate a faulty sensor or wiring issue
https://www.obd-codes.com/p0138
P2270 points to other probable causes like an exhaust leak
https://www.obd-codes.com/p2270
so be aware a new sensor might not resolve your issues
Old Dec 27, 2019 | 08:07 AM
Probably need a new #2 sensor. That is the one after the cat.
P0138 This is one of those descriptors that does not mean anything like what it sounds. What it really means is that the sensor is stuck in the test for rich.
P2270 actually means the sensor is not able to read a high enough voltage.
Old Dec 27, 2019 | 08:43 AM
Thanks Don. I'll get one in and see what happens.
Figured #2 was after the cat, but wanted to make sure.
BDR1973
Nov 22, 2016 01:16 PM
cjmickel
Feb 4, 2014 06:18 PM
08SSREDHHR
Aug 14, 2012 10:11 PM
techno ed
2.4L Performance Tech
Aug 13, 2012 06:36 PM
asanti
Sep 9, 2011 11:08 AM
