P1516 & p2101 2007 hhr lt
Driving home today my car stalled and gave me Engine Reduced Power indicator and check engine light. Resulting codes were P1516 & P2101.
My friend came and looked at it and said I probably had to replace Throttle Body. I waited about 30 mins and was able to drive about 2 more miles home.
Should I replace the Throttle Body? Any brands recommended? GM Bosch Std Motor?
Or any other recommended action?
thanks
thanks
My friend is not a mechanic but he works at a shop. He said he previously had something similar with his vehicle and he resolved by replacing the throttle body.
I personally am not qualified to test the TB. Any opinions on the Throttle Body brands?
I used an OBDII diagnostic scanner.
I’d investigate a little check the wiring harness for any shorts, don’t throw parts at it when it could be simple fix
https://www.obd-codes.com/p2101
Could be just a low battery or a dirty TB or a bad connection. The 2 codes a basically the same, the difference being one is a bad signal for .3 seconds and the other is for .5 seconds. I would suspect a wire or connection before the TB.
They mean the butterfly is not where the computer thinks it should be.
I concur
A good and proper throttle body clean and physical inspection of components
Reset the light and a spirited road test.
All good after? Get it home and have a beverage of choice to a job well done.
I don't readily see any loose wires or bad connections. Wiring harness looks pretty solid.
The throttle body currently in there is a no name generic about 1.5 years old that I don't have much faith in.
I think I'll just order the TB from Rockauto. GM GENUINE 12694875.
Hope that solves it.
