Power steering error?
Old Sep 20, 2025 | 04:09 PM
jimvw's Avatar
OK, so 3 years ago I had my Power Steering fail. Took it in to the local dealer who fought with me about changing the P.S motor under the warranty/recall. They finally did at no charge. Today I drove down to the bank (about 5 miles) and when starting it up to return home, The power steering message came on, and no steering. I shut it off and restarted it, and error was gone. No problems driving home. Anyone seen this after the warranty/recall was done? If I take it in to the dealer, are they going to do the campaign again for free? Luckily I don't have to drive to work every day (retired) but still don't want to get stuck somewhere without steering.
Old Sep 20, 2025 | 06:44 PM
I’m pretty sure they will have to change the motor n/c if you have the letter sent out. I think there’s a copy around here somewhere.
Old Sep 20, 2025 | 07:24 PM
It depends on the part number they installed. If they installed the updated part number they won't do it. If they didn't bother to check and installed the old part they need to replace it.
It also depends on the exact error.
The correct re[placement part number is in the TSB/recall/warranty.
Old Sep 20, 2025 | 09:02 PM
jimvw's Avatar
I gave them a copy of the TSB/recall/warranty and they ordered the part, but i never heard what they replaced it with. I assumed they used what they were supposed to for the N/C repair.
Old Sep 20, 2025 | 10:13 PM
PulpFriction's Avatar
2010-2011 got the power steering recall. 2006-2009 gets "Special Coverage" that is basically a lifetime warranty. I don't see why a previous repair would matter; if it's broke they're spoda fix it, "for the life of the vehicle, regardless of ownership."
Old Sep 21, 2025 | 10:49 AM
jimvw's Avatar
sounds good to me!!
Old Sep 21, 2025 | 11:09 AM
If no, then try a different GM dealership
Old Sep 21, 2025 | 12:00 PM
Cadillac, GMC, Buick
Old Sep 21, 2025 | 04:35 PM
jimvw's Avatar
Ah yes, the joys of rural / small town life... I guess I will see if it happens again, and maybe a new battery. the one in there now is a bit old... only one Chevrolet dealer in town, the other dealer handles Ford, Chrysler, Dodge, Jeep...
Old Sep 21, 2025 | 04:49 PM
Tighten that torx bolt and the 4 fuse box bolts and push all the fuses and relays firmly in place
