Rear axle issue! I need some "how to" Help
Old 04-21-2007, 11:21 PM
zhris's Avatar
Question Rear axle issue! I need some "how to" Help
Well, I found out I have a bent rear axle yesterday. Right rear tire is toe out and camber off the chart. There is a bend in the rear axle going down and forward like someone hit the tire with thier bumper or something. Rim is fine, not bent and balanced fine. I am thinking I am going to replace this myself if I can find the parts used. I am thinking it is going to be the same in either cobolt or hhr, but I don't know. Anyone else done this? Any advice??
zhris is offline
Old 04-24-2007, 11:41 AM
zhris's Avatar
OK, the rear axle kit is for the HHR only! The Cobolt is a different unit, making it even harder to find a used one. I am really not wanting to spend the $1000 for a new one.
zhris is offline
Old 04-24-2007, 12:21 PM
KY Dave's Avatar
Are you out of warranty?
KY Dave is offline
Old 04-24-2007, 01:17 PM
SoCalHHR's Avatar
The rear crossmember and related pieces are more like $1500.
Check GM Auto Parts.com
SoCalHHR is offline
Old 04-24-2007, 01:36 PM
Black Rose's Avatar
Warranty likely woudn't fix that. If someone hit it, you're likely looking at an insurance job to fix that.
Maybe you'll luck out and find a junker that has front end damage only.
Black Rose is offline
Old 04-24-2007, 02:24 PM
solman98's Avatar
Why can't your insurance take car of this? I would leave it to professionals.
solman98 is offline
Old 04-24-2007, 09:06 PM
zhris's Avatar
Well, I have a $1000 deductible. I was thinking if I could fix it for less than that I would just do it myself. Quote from the dealership was $2300 with $1250 of that in new parts. I have been trying to find parts used but there are not alot of Wrecked HHR's out there yet. I have actually only found one and it was a pretty bad rollover, good news is the guy survived. I was hoping a cobolt would have the same parts but no such luck. I think I am just going to have to shell out the money.
zhris is offline
Old 04-25-2007, 10:12 AM
KY Dave's Avatar
How do you know it wasn't defective from the factory? I would push to get the part fixed under warranty. Do you recall anyone hitting you or sliding into a curb?
KY Dave is offline
Old 04-25-2007, 11:07 AM
GCarp's Avatar
If someone hit you, wouldn't there be a mark somewhere?
GCarp is offline
Old 04-25-2007, 02:47 PM
zhris's Avatar
The way the axle is bent indicates someone hitting it, it is down and at an angle, not consistant with the point the tire touches the road, like someone hit the tire in the 10 o'clock position. I have 12k miles so if it had come like that from the factory the tire would be bald, not near perfect like it is. I am just coming to terms with the fact I am going to have to pay the insurance deductible. I cannot find the parts for less than $1000 and if I am going to pay that for the part, I may as well have someone else do the work for the same amount of money.
zhris is offline
Quick Reply: Rear axle issue! I need some "how to" Help
