Rear hatch won't lock or unlock
Every thing locks 'except' the rear hatch when using the remote or the doorbuttons.
When the hatch is closed it still opens with the touchpad. It also engages mechanically when closing the hatch.
When the hatch is closed it won't lock with the door buttons or the remote, yet it sets off the horn alarm when the hatch is opened while set in lock mode.
Bottom line is the hatch works, it just won't lock.
Solutions or troubleshooting/testing ideas are appreciated.
TIA
TIA
sky,
Did you get this problem fixed? Here is a prelimanary bulletin on this subject.
https://www.chevyhhr.net/forums/show...post336171#182
Brad, is there any TSB help with the rear hatch lift cylinders working slow in the cold weather. Mine are alot worse this winter than last. I'm taking the HHR in for this problem tomorrow and was wondering what you do when a customer complains of the cylinders working slow.
Thank's, Jim...............
