rear power window switch
Old May 9, 2018 | 02:20 PM
ezstriper's Avatar
can you remove the rear power window switch without removing door panel ? thanks
Old May 9, 2018 | 02:48 PM
I think you can, but the wires are pretty short. It is not difficult to pop the trim panel off. Check on youtube for replacing the rear speakers.
Where in Fred are you. I'm around Harrison crossing.
Old May 9, 2018 | 03:26 PM
ezstriper's Avatar
river rd...31 years
Old May 9, 2018 | 03:28 PM
Cat Man HHR's Avatar
I just looked on Rock Auto to see what the switch looks like
The side of the switch has 4 feathered tabs meaning it must be installed inside pushing out.
I went on GM Parts Direct and looked up door panel, it shows the finger well but no exploded picture of it.
Looking at mine, when you remove the cover for the finger well/door pull, there are two 30mm (?) torque bolts. There is a parting line between the finger well and door panel which could indicate it "might" pop out.
You could send a PM to hells hot rod, he parts out HHR's and might have a door panel off and give you some insight.
Sorry couldn't help you more.
Old May 9, 2018 | 03:35 PM
ezstriper's Avatar
thanks...have the GM switch, somebody said thought you could get it out from top, does not look that way to me...
Old May 9, 2018 | 03:46 PM
PM Hells Hot Rod, he's a good person. Ask him if he can take a picture of the inside of the door panel. I looked on youtube and can only find how to remove the panel, but no good views of the switch area.
Other GM models can be taken apart without the door panel removed.
Old May 9, 2018 | 04:04 PM
ezstriper's Avatar
yes, and every one I found is a earlier one, mines a 11
Old May 9, 2018 | 04:05 PM
They are all the same year does not matter.
I'm stuck in a wheelchair, but I could coach you on removal.
Old May 9, 2018 | 04:07 PM
Well take the panel off and document what you're doing. I'm sure a sticky could be made of it.
Old May 9, 2018 | 06:50 PM
The door panel come off easily, the two T30 screws in the finger bowl, one hidden behind the round plug by the inner door handle. Then the little plug button on the rear edge of the door panel, pop the retainers , lift the panel up and off , careful with the handle cable.
