Removal of Interior Vinyl dress up coatings?
I just purchased a 2nd low mileage used 2011 HHR from a non GM dealer and as usual the Prep Dept. coated the Dash and all side Door panels etc with an Obnoxious clear shinny coating to dress up the interior vinyl. UGGG!!
Why they indiscriminantly do this blows my mind as it has a crappy sweet smell and emits fumes into the cabin air that gave my wife a head ache within 20 minutes.
Too late to cry over spilled milk but I would like some suggestions on what you think works best to use for Removal without doing damage/discoloring to the vinyl.
Will appreciate your input.
SF
SF
I also recently purchased a low mileage 2011 and the Buick dealer I bought it from did the same thing, it will dissipate on it own in a week or two on its own if you can put up with it for that long. My sinuses are messed up so I have no sense of smell, it didn't bother me.
I finally got a hold of the dealers Prep company and had a talk with the owner. He said in 15 years he has never had a complaint. HuH??
Maybe nobody but me cares enough to say something and check it out.
It's Armorall just as I thought.
I did take some 90% rubbing alcohol to the steering wheel just to see what would happen. I just quickly touched it lightly and had a clean paper towel to wipe it immediatly.
It did cut it but left it sticky/tacky until I rubbed it lightly with the paper towel.
It felt a little hairy when it got sticky but that is probably because it was the Armorall softening not the vinyl.
I might give Meguires Vinyl cleaner a shot before I go any further.
It's a touch and go when your testing for the right solution here.
Sure don't want to damage the Vinyl.
I contacted a high end Detail shop also and they were familiar with the issue.
They use a commercial product to clean and then a special non smelling conditioner to finish but they want $250 to do mine.
I'll wait till I see what I can do first.
SF
If you have a complaint with the delivered product, try complaining to the vendor?
I agree ArmorAll has a horrible feel to it, people just don't complain because it's shiny. You are not melting vinyl with alcohol! maybe with GOOF OFF (lighter fluid/dry cleaning solution) Vigorous scrubbing with alcohol would probably work (discrete test location advised).
Go to the local auto parts store and find out what the solvent is in Armor All, it should be on the contents label (the first listed component). That will remove it.
Being in the boating business for many years I found many little tricks to defeat difficult problems.
Acetone and Alcohol were 2 of my regular tools. Just have to know when to use and when not to.
I had Laquer thinner too but didn't use as much.
My motto has always been when in doubt .. Proceed with Caution !!
SF
