removing stick on mirrors
Old May 29, 2011 | 04:12 PM
  #31
You shouldn't need to.... WD40/lighter fluid/etc. would melt the glue well enough that a blade wouldn't be necessary. (Remember what happened with the stripe? Stay away from blades. Man)
Old May 29, 2011 | 04:24 PM
  #32
LawDog88's Avatar
Bah humbug..
Old May 29, 2011 | 04:36 PM
  #33
Seriously though, that type of solvent, and a rag after you cut through the tape with the fishing line (floss is an okay idea too) should clean up nicely.
Old May 29, 2011 | 04:42 PM
  #34
LawDog88's Avatar
WD40 can seriously do that to adhesive?
Old May 29, 2011 | 05:25 PM
  #35
Yep!
Old May 29, 2011 | 09:52 PM
  #36
did you use any kind of blade at all?
Never on the mirrors, it will scratch them.. Sure as can be..
Old May 30, 2011 | 03:21 AM
  #37
LawDog88's Avatar
Thanks guys.
Old Jun 1, 2011 | 08:53 AM
  #38
pipes's Avatar
yappers a can a WD 40 a pair a vise grips some duct tape a hammer and couple a screw drivers a fix about anything :thum
Seriously WD 40 works great for that so does Goo Gone and it smells better IMO anyway .....
Old Jun 1, 2011 | 08:57 AM
  #39
Many of those oil type solvents are a similar base, so I usually use what's handy at the time. Just stay away from acetone/lacquer thinner types as that could ruin your paint.... and your day!
Old Jun 1, 2011 | 09:47 PM
  #40
urbexHHR's Avatar
Why are you taking them off? I'm actually thinking of adding a set to mine...
