Reset the oil life indicator..The easy way
Old Feb 20, 2009 | 09:00 AM
mynameistaken's Avatar
Originally Posted by RUDEINC
I stumbled across this weekend while I was programming my nitrous control unit. The easy way to reset the DIC oil life monitor. It's just like other GM vehicles that use the oil reset feature. Some of you may already be familliar with this. Here are the steps...
1......Key on ,not running
2......Step on the gas pedal to the floor 3x in 5 seconds or less.
3......Oil life indicator will go back to 100%
This works out great for me, because I can never remember how to do it using the steering wheel controls. I always end up looking in the owners manual...lol...Just thought I would share....Regards
SWeet! just did it!
Old Feb 20, 2009 | 12:25 PM
Jeff®'s Avatar
That method doesn't work with the SS.
Old Feb 20, 2009 | 01:35 PM
camaro98z28's Avatar
Um, for the HHR SS you have to Press the INFO Button on the steering wheel when it gets to the Oil Life %. Hold that button and the Arrow Button at the same time. Release and it will say "Oil Life Reset". Press arrow button again and it will then say something like "Confirm" Wut Ever. Press Arrow again and it will then go to 100%
Old Feb 20, 2009 | 03:08 PM
cobb28's Avatar
Originally Posted by Black Beauty
if you`re altering the computer by resetting this way, what else is changing you can`t see?
I totally agree. I think you should go by the book when it comes to vehicle computers. I could see using this alternate method if resetting the way intended does not work for some reason, but other than that I figure it's probably in the manual for a good reason. Just my opinion.
Old Feb 21, 2009 | 12:06 PM
mongo's Avatar
It's legacy code from earlier systems, the shop truck is a 06 Silverado that has no steering wheel controls and a much simpler DIC display. More advanced system build code on top of the basic code rather than rewrite from scratch. It was likely considered to be easier for the end user to understand if all changes to the display were done thru the steering wheel controls. BTW, the switch between metric and US display is a real PITA. If anyone knows a shortcut that can be done safely without having to stop somewhere it would be appreciated. (My 92 S-15 Jimmy has a US/metric pushbutton- sometimes simpler is better)
Old Feb 21, 2009 | 03:31 PM
masterchief1112's Avatar
i think the only way to do it is through the DIC. did it by accident last time i changed my oil and found myself going waay too slow on the eway.
Old Feb 21, 2009 | 03:34 PM
mongo's Avatar
Used the shortcut last two oil changes- no issues.
Old Feb 21, 2009 | 03:36 PM
ChevyMgr's Avatar
No hard time... just seemed a little strange, not to mention, if you`re altering the computer by resetting this way, what else is changing you can`t see?
Nothing is changing.
Old Feb 21, 2009 | 05:43 PM
pg318's Avatar
Last time I drove through Canada I realized that without the ability to change over (didn't have the manual with me) there was no way of telling whether I was speeding, there being no secondary marks on the speedo...OK no way of telling how much I was speeding
Old Feb 21, 2009 | 09:29 PM
chevyorange's Avatar
Resetting the oil life monitor is the same as resetting the trip milage. When you get toggle past the trip odo's and get to oil life, just hold the arrow button to reset. Simple!
