Rhino Ramps
Old Jun 29, 2011 | 02:54 PM
diskullman's Avatar
Rhino Ramps
My old steel ramps are too steep for the HHR, and damaged the paint on my front facsia a little bit. Does anyone have Rhino Ramps (plastic Pep Boys type) and if so, is there any problem using these?
Old Jun 29, 2011 | 03:17 PM
capp002's Avatar
i have them, and have no issues.
Old Jun 29, 2011 | 03:39 PM
X2.... no issues at all with those ramps.
Old Jun 29, 2011 | 06:56 PM
Early63's Avatar
They work great for oil changes! I use the on my HHR and Trailblazer.
Old Jun 29, 2011 | 09:33 PM
Have 'em, they work great, all smiles here!
Old Jun 29, 2011 | 09:45 PM
bk94si's Avatar
Are they strong enough for a Suburban? I need some new ramps. I bent my old ones with the Burb.
Old Jun 29, 2011 | 09:50 PM
Well they hold 4,140 lbs of '67 SS without complaint. They come in two weight ratings, either 8,000 lb or 12,000 lb, I think most Suburbans come in around 5,800 to 6,100 lbs.
Old Jun 29, 2011 | 09:59 PM
bk94si's Avatar
Sounds good, thanks.
Old Jun 29, 2011 | 10:05 PM
Rod Run's Avatar
I'm lowered with Pedders springs and they still fit fine
Old Jun 30, 2011 | 09:14 AM
Jeff®'s Avatar
I'm wanting to make these myself.
http://www.mustangworld.com/ourpics/...amps/index.htm
