Rim Question
Old Oct 18, 2022 | 04:49 PM
nate_o23's Avatar
Rim Question
Hi all I have a question on HHR rims. My 2007 HHR originally had 16" rims on it but currently 2 of the rims are in bad shape. I have a line on some 17" rims off of a later HHR. Is there any compatibility concerns as far as bolt pattern or offset I should be aware of?
Thanks
Old Oct 18, 2022 | 07:16 PM
No.
Old Oct 18, 2022 | 09:23 PM
Are you planning to replace all 4, or just the 2 bad ones?
Old Oct 19, 2022 | 05:53 AM
nate_o23's Avatar
Probably all 4. I'm guessing it would be a bad idea to mix 16 and 17 in rims
Old Oct 19, 2022 | 05:57 AM
Lonwane's Avatar
As donbrew stated, no.
ALL HHR wheels came with the same bolt pattern.
There are even wheels from other vehicles that are the same.
Me, I have 17" wheels from a Saab 9-3.
Old Oct 19, 2022 | 08:17 PM
nate_o23's Avatar
Ok thanks for the help
Old Oct 19, 2022 | 10:31 PM
jimvw's Avatar
It will probably affect your speedometer reading and the odometer.
Old Oct 20, 2022 | 12:19 AM
PulpFriction's Avatar
Not problem, will look nice. Any 5-lug wheel from any HHR, Cobalt, or even G5 will work.
There will be no speedo issues with 17” if you use the correct 215/50R17 tire that came on 2LT’s. It’s about the same diameter as the 215/55R16 base tire.
Baylor2020
Tires & Wheels
Jul 24, 2020 07:13 AM
Kimberly Snyder
Aug 25, 2019 09:51 AM
Talvanos
Tires & Wheels
43
Jul 29, 2011 08:36 PM
RICANBABY
Tires & Wheels
11
Nov 4, 2009 02:43 PM
