Rough idle
Old Dec 23, 2024 | 04:07 PM
I don’t recommend carb cleaner for cleaning the throttle body . Or brake cleaner!
Old Dec 28, 2024 | 05:29 PM
Gearhead1's Avatar
Rough idle….update
I have: checked, no codes.
Checked air filter
Took MAF out cleaned it with CRC
Took T/B off….cleaned it (it was pretty dirty)
No change. At about 194-196F rough idle starts and gets progressively worse as it gets hotter…at 217F radiator fan comes on an I would have thought that as it cooled down it would return to normal smooth idle once below 194F but it does not. I can turn it off and crank it again and will idle smooth until 194F and above. So far it never stalls but it sure makes you think it will. And touch accelerator petal the car picks right up with no issues.
I havent found and vacuum leaks but have not ruled that out.
So I’m thinking may try some 4 Power fuel system cleaner. Sure seems like have a lean fuel issue idling at higher temps.
Any suggestions?
Old Dec 28, 2024 | 08:13 PM
pfmeeks's Avatar
When was the last time you changed the spark plugs and coil packs ?
Old Dec 28, 2024 | 08:48 PM
Gearhead1's Avatar
I will have to look in my maintenance log book for the car on the plugs see how many miles on them…coil packs I have never changed
Old Dec 28, 2024 | 10:02 PM
pfmeeks's Avatar
It sounds to me when the engine is getting hot you have a coil pack or packs going bad. Id change them.
Old Dec 28, 2024 | 10:35 PM
Gearhead1's Avatar
Well, you might be right but what makes me think that is not it….I can barely increase the throttle or take off from a traffic light and the car runs fine…no missing or sluggish
Old Dec 29, 2024 | 09:29 AM
pfmeeks's Avatar
At low idle the coil is "firing" at its lowest, when you accelerate it has to give more fire for the demand which can overcome the misfire issue. It also can be a spark plug causing your problem. If you have that many miles I would change the plugs and coil packs for sure. Id bet that will fix your problem.
Old Dec 29, 2024 | 12:18 PM
PulpFriction's Avatar
Take a look at the plugs before deciding to fool around with the coil packs. They're almost always fine. They don't wear out, and they don't fail at the same time. In the unlikely event that you have one bad coil pack, change just that coil pack, and be sure to use OEM.
Old Dec 29, 2024 | 12:26 PM
Coil spark voltage isn’t variable or controlled by throttle plate angle.
Old Dec 29, 2024 | 01:08 PM
Gearhead1's Avatar
Thanks for the suggestions guys….I was about to ask if secondary voltage from coils to plugs actually varied….never really seen that before.
Guess need to look up the mileage I have on current spark plugs and what kind they are.
To be honest, I didnt put the correct A/C thermo in it when I first got it…maybe the ECM aint liking it and causing the rough idle at temp….but again, wouldnt there be a DTC related?
Since we buy fuel for this car all over the country, think I will give the injector clearer a try for good measure….check/change plugs….see about thermo from Rockauto
