RPO Code lists (Options)
Okay, I called my local Chevy dealer (parts dept.) today and they don't print (or order) those Service Parts ID labels.
I'm hoping there's some GM data base that can help me.
And just fyi, I asked the dealership what the cost would be for a 2nd "remote" key fob and for a 2nd ignition key with chip.
The remote was $113 and the blank key was $37! The service dept. woman said, w/o her computer functioning at the time, that
programming both of those would be over $100. YIKES!!
The Service department can get the RPO list, which is different from "Service Parts ID". I don't know why you are frantic about it, there were only a couple of options and they are pretty obvious.
You can get a fob and programming module from eBay, a new key with chip also on eBay. Key programming instructions in your Owner Manual.
Learn how to use our search tool, it will save you grief and time.
Merchandising Model : 1AS26 -2008 CHEVROLET HHR PANEL LT
Gross Vehicle Weight Rating : 1925 kg (4245 lb) Order Number : MJSXXX
Build Date : 11/08/2007 Build Plant : 38SA
Warranty Start Date : 02/16/2008
OPTION CODES
AJ6 - PWR SEAT ADJUST-DRIVER, 8 WAY
AK5 - DRIVER/RIGHT FRT PASS AIR BAG
AL0 - SENSOR INDICATOR,FRT PASS/CHILD
AP3 - REMOTE STARTER SYSTEM
AP9 - CARGO CONVENIENCE NET
AR9 - FRONT BUCKET SEATS,DELUXE
AXS - VIN IDENT PANEL VAN
BG2 - CARGO MAT, REAR 2-PIECE, FULL LENGTH
BVE - RUNNING BOARDS, COLOR KEYED
B57 - BRIGHT CHROME APPEARANCE PKG: *BRIGHT CHROME GRILLE *BRIGHT CHROME O/S MIRRORS *BRT CHROME LIFTGATE APPLIQUE *BRIGHT CHROME DOOR HANDLES *BRIGHT CHROME ROOF RAIL END CAPS(WHEN PURCHASED)
C2Y - GVW RATING 4,240 LBS
C67 - AIR CONDITIONING
DD8 - LIGHT SENSITIVE ISRV MIRROR
DG7 - MIRROR,O/S ELECT REMOTE CNTRL
DT4 - ASHTRAY AND LIGHTER
D7E - STORAGE, CARGO AREA, LOCKABLE
FE3 - SPORT TUNED SUSPENSION
FE9 - 50-STATE EMISSIONS
FX2 - 3.91 AXLE RATIO
G63 - LUGGAGE CARRIER ROOF RAILS
IPB - TRIM INTERIOR DESIGN (PB)
JJD - I/P SUBASSEMBLY NOT INSTALLED
JL4 - STABILITRAK
JM4 - 4-WHEEL ANTI-LOCK BRAKE SYSTEM
LE5 - ENGINE, 2.4L HIGH OUTPUT ECOTEC
MN5 - 4 SPD AUTO TRANSMISSION, HMD
MX0 - TRANSMISSION, 4 SPD AUTOMATIC WITH REMOTE VEHICLE START
NP5 - LEATHER WRAPPED STEERING WHEEL
NT7 - FEDERAL EMISSION SYSTEM TIER 2
NW9 - TRACTION CONTROL
QBV - TIRE, P215/50R17-90S BW ST TL
QP2 - WHEELS, 17" POLISH ALUMINUM (REPLACES STD/OPT WHEEL)
R9N - PROCESSING CODE - SEAT
R9U - GM ACCESS - AUTOBOOK IDENTIFIER
SAL - RAMOS ARIZPE, MEXICO PLANT CODE
SLM - STOCK ORDERS
T37 - FOG LAMPS
UE1 - 1 YR ONSTAR SAFE & SOUND (ASK DLR ABOUT TURN-BY-TURN NAV UPGRADE)
UQ3 - AUDIO SYSTEM HIGH PERFORMANCE WITH 7 PIONEER SPEAKERS
US8 - AM/FM STEREO, CD PLAYER, MP3 FORMAT, W/AUX INPUT JACK (REPLACES STD/OPT RADIO)
U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3MONTHS INCL.
VT7 - OWNERS MANUAL ENGLISH
VY7 - LEATHER WRAPPED SHIFT KNOB
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
1SZ - OPTION PKG DISCOUNT
19B - EBONY
19I - BLACK INTERIOR TRIM
2LT - 2LT PREFERRED EQUIPMENT GROUP: *2.4L HIGH OUTPUT ECOTEC ENGINE *CHROME EXHAUST TIP *SPORT-TUNED SUSPENSION *LEATHER WRAPPED STEERING WHEEL *STEERING WHEEL RADIO CONTROLS *LEATHER WRAPPED SHIFT KNOB *INSIDE REARVIEW MIRROR, AUTO DIMMING, COMPASS *AUDIO SYSTEM, HIGH PERFORMANCE WITH 7 PIONEER SPEAKERS *WHEELS, 17" PAINTED ALUMINUM (REPLACES STD/OPT WHEELS) *BRIGHT CHROME GRILLE *BRIGHT CHROME O/S MIRRORS *BRT CHROME LIFTGATE APPLIQUE *BRIGHT CHROME DOOR HANDLES *BRIGHT CHROME ROOF RAIL END CAPS(WHEN PURCHASED) *FOG LAMPS *ANTILOCK BRAKE SYSTEM *STABILITRAK-STABILITY CONTROL TRACTION CONTROL SYSTEM *RUNNING BOARDS, COLOR KEYED
50U - SUMMIT WHITE
6AE - FRONT SPRING
7AE - FRONT SPRING
Has anyone found a factory "build sheet" or what some call, a "broadcast sheet" - under say, the back seat cushion or on top of the gas tank?
My glovebox door Service Parts ID sticker was pulled off and tossed before my ownership. And I just can't afford the $100 that Chevrolet / GM Heritage wants for this service!
I believe I have a pretty loaded LT2 and one thing I need to know is if my 2006 has the FE3 "sport suspension" - so I can order the correct replacement control arms, bushings, and other worn-out suspension parts.
It just would be nice to have my HHR's installed equipment list.
What correct replacement parts? About the only difference between the FE3 and alternative FE1 suspension you need to worry about is the sway bar diameter for the correct sway bar bushings!!! For that you will need to measure the bar - it will be either 23 or 25 MM. If your sway bar measures out at 23 mm then you have the FE1 suspension. All the other components such as the lower control arms, control arm bushings, ball joints, struts are all the same.
The 2006 sway bar diameter was usually 23mm it was determined by serial number
https://www.chevyhhr.net/forums/comm...-thread-48833/
all the other FE3 parts numbers are in there too!
2LT has "Sport". Mostly won't find FE1 parts; I can't even tell the difference maybe the springs are different but all of the parts are interchangeable, except for the aforementioned sway bar bushings.
