Shimmy at 60mph???
I had the same problem with the shimmy off the lot when I bought mine. The dealer replaced both front Firestones and it fixed the problem. They said the tires where out of round. I've got the polished 17's as well.
Bought a 2007 HHR LS Back in july, and had the same problem, My father who owns a tire shop, checked them rebalanced them, test drove them and had the shake. We slapped a new set of cooper cobra tires on there and the shake went away. I have since bought rims and new nexen 5000 tires, and the ride is smooth. We are convinced that it is the Firestones.
It might cost you a few dollors but take it to a tire shop and have them dismount the tires from the wheels and see if there is something in one of them. I worked in a tire shop once and we had this problem on a car we put tires on, one of the tires had a flat fixed and an awl use to remove nails or other objects was left in the tire when you drive slow it rolled around inside the tire making it out of balance. May be worth a shot.
Here is an interesting twist. After leaving a restaurant today I felt a very bad vibration around 40MPH. After pulling over I noticed snow inside the rear wheels that must have gotten in there when I parked in an unplowed spot. After pushing out the snow and continuing on my way, the vibration was gone. In all my years of driving, I have never had this happen. Has anyone else experienced this?
Yes! We had a snow storm on Sunday and I had to push a little snow getting up my driveway and it warmed up Monday and turned into a real mess. Tuesday noon huge vibration, …..just about shake the wheel out of my hands and in the gas petal too. Pulled over and there was some (not large amount) of ice inside one front wheel, cleaned it out and it drove fine. I have never had this happen before and have driven many different vehicles in these conditions before, it would appear that the 17 inch HHR wheel (at least) is very sensitive to balancing.
