Smooth door lock knobs
Old Apr 25, 2007 | 08:15 AM
mizzouHHR's Avatar
Originally Posted by JoeCanadian69
SO if i just grip onto the stock locks that are there now with pliars and pull it should pop off??
It helps to turn it as you pull. They are not threaded on, but there is a "thread" pattern to the shaft the knob is on
Old Apr 25, 2007 | 08:31 AM
SICKS.OH's Avatar
mine would NOT just pull off. i had to twist them off.
Old Apr 25, 2007 | 08:39 AM
JoeCanadian69's Avatar
IS there any way to modify the factory shaft so that the locks dont pop up as high??? ...and also isnt haggered looking
Old Apr 25, 2007 | 09:23 AM
SICKS.OH's Avatar
yeah. i pulled the knob off, and used a dremel cut wheel to trim the "shaft" off. i think i took 3/8in basicly used needle nose pliers to hold it, and cut what i could off. i also trimmed the knob a little bit.
Old Apr 25, 2007 | 09:36 AM
So does the pop-up that sticks out of the door have a hole on the bottom that a rod from the actually Door lockset goes into??
Old Apr 25, 2007 | 10:21 AM
  #26
Yes, the factory knobs are hollow, and the rod inserts into knob.
Old Apr 25, 2007 | 10:30 AM
  #27
SICKS.OH's Avatar
Old Apr 25, 2007 | 12:05 PM
  #28
Ahh i see!!! awsome!!
Old Apr 25, 2007 | 01:21 PM
  #29
DreamHHR's Avatar
For those located in Canada with a black interior, CT sells a door knob assortment (4 pairs) for Fords, of which one pair is black and looks like a perfect fit. $5.79 in the Help! section.
I'm planning to cut mine and reuse the OEM knobs, but if I screw it up I'll pick up a set.
Yves
Old Apr 25, 2007 | 01:24 PM
  #30
For only 5 bucks, you might want to have them on hand. No matter how carefully I tried to remove mine, they all broke. I wouldn't even have attempted one without having the stubbies on hand already.
