Speedometer Accuracy with larger Rims
Old Nov 19, 2008 | 04:16 PM
ChevyMgr's Avatar
Originally Posted by hyperv6
The best thing for you to do if your wanting to keep everything accurate.
GO to the Tire Rack web site and choose you tires by Diameter and Revolutions per mile. IF you keep them close it will keep your dash accurate.
I looked up the spec on my 18's on the SS and matched my winter tires to the sames spec only on a 16 inch wheel. I am off 2 Rev Per Mile from the factory tire. That is about as yout going to get.
Also same tire sizes will vary from MFG to MFG. A 215 55 16 from Firestone is not the same diameter as a BFG or Goodyear. They will be close but not exact.
If you are within 5% of the originals the difference is minimal.
And we know from members who have GPS that the clusters are not accurate to begin with. You never know, you may change to a size that is more accurate than the GM setup.
Old Nov 19, 2008 | 08:13 PM
rommer's Avatar
HP Tuners can adjust for different size tires plus your car can go faster too!
Old Nov 19, 2008 | 08:26 PM
Cokeybill's Avatar
use this 1. just put your oem tires & rims in and your new 1s in. then scroll down.
http://www.rims-n-tires.com/rt_specs.jsp
IMPALADAKID
Fuel Economy - Hypermiling
19
Jul 8, 2013 07:25 AM
lena
Tires & Wheels
10
Jan 3, 2013 04:02 PM
wba
May 16, 2012 08:52 PM
texaselky
22
Nov 25, 2009 05:26 PM
Rikki Sixx
Tires & Wheels
22
Oct 16, 2008 10:44 PM
