steering column replacement tips needed
Old Nov 11, 2021 | 07:54 PM
tsbrewers's Avatar
Hey all, I have an '06 2LT that has a rattle in the steering column. I am quite sure that it is coming from somewhere above the intermediate shaft, possibly the clock spring, etc.
Anyway, I picked up a used column from a u-pull type recycler, that includes basically everything above the intermediate shaft, motor, column, wheel, etc. The donor was a 2010 LS. I am planning on swapping some parts out to see if I can find the rattle. The biggest question I have is, the "new" column's steering wheel was locked at an angle, and I am wondering how you go about unlocking the wheel? I don't have the key for the "new" column, though it does have a lock cylinder installed.
Really just looking for some tips from anyone who has done something like this before? Especially the locked steering wheel.
Thanks,
Old Nov 11, 2021 | 08:14 PM
You will need to remove the key cylinder and PK3 sensor and switch them. I don't know to do it without a key.
I don't know what would cause a rattle. If the clockspring was bad the horn would not work; they usually do a scrape sound.
Old Nov 11, 2021 | 08:30 PM
tsbrewers's Avatar
Thanks, I'll see if I can figure out the key and sensor.
This isn't a scrape, it is a rattle, like something is loose. AFAIK, the horn and everything else work perfectly. To me is honestly sounds like the rattle is come from more the upper left side of the dash, like just left of the cluster. But it is in the steering somewhere. I might throw in a new intermediate shaft just to make 100% sure that is crossed off the list, but it really sounds higher up and is not a clunk that I would expect read about from the shaft.
Old Nov 12, 2021 | 06:54 AM
Take out the plastic surround for the instrument cluster, look for friction marks on the plastic, there’s were a noise can generate.
I wipe a dab of dielectric grease on those points . No rattle
Old Nov 12, 2021 | 06:56 AM
tsbrewers's Avatar
Thanks, I'll give that a look this weekend.
Old Nov 12, 2021 | 06:57 AM
Sometimes we look past the obvious to get to more aggravation
serch826
Oct 22, 2017 06:02 PM
bikerboy89
Jun 3, 2017 06:44 PM
MCHHR
Oct 4, 2016 03:00 PM
BeanWagon
Feb 3, 2012 03:42 PM
scrambler
Jan 17, 2009 07:50 AM
