Stupid Question of the Day re Daytime Lights
Old Dec 11, 2007 | 09:49 PM
Dave C's Avatar
Originally Posted by itschaboykenny
Violet: This should be your answer..
Daytime Running Lamps (DRL) ......................SNIP
The DRL system will make both front turn signal lamps
turn on when the following conditions are met:
• The ignition is on.
• The exterior lamp control is turned to AUTO.
• The light sensor detects daytime light.
• The shift lever is not in PARK (P).
What you see are NOT the parking lights, BUT the turn signal lamps on continuously. Much brighter than parking lights.
Gotta be legal or can you say recall.
PS Where is Courthouse Deb when you need her ?
Old Dec 11, 2007 | 10:01 PM
Daverb's Avatar
If your not sure, then why not just turn the switch to turn on the headlamps on, or turn off the driving lights
Old Dec 11, 2007 | 10:02 PM
pg318's Avatar
No, parking lights are the low wattage filaments in the amber bulbs, the driving lights are done by using the high wattage filaments normally used for the turn signals. Been done that way on Chevys for many years now. I suspect that they've moved to the headlight DRLs for one main reason - the amber bulbs get really hot, and tend to fail ofter, even when they're the correct bulb with the high temperature base.
Old Dec 11, 2007 | 11:33 PM
Kingfrog's Avatar
Turning on the Fog Lights will turn off the orange running lights for daytime driving.
Old Dec 11, 2007 | 11:35 PM
Originally Posted by Violet_HHR
Mine appears to only have the parking lights on during the day. (My headlights are set on auto) That is illegal in Colorado. I did a search to confirm it:
You might want to do a little more thorough search. Statute 42-4-231 has a "provision" in it that refers to 42-4-204. 42-4-204 states when lights are required.
42-4-204........
(1) Every vehicle upon a highway within this state, between sunset and sunrise and at any other time when, due to insufficient light or unfavorable atmospheric conditions, persons and vehicles on the highway are not clearly discernible at a distance of one thousand feet ahead, shall display lighted lamps and illuminating devices as required by this article for different classes of vehicles, subject to exceptions with respect to parked vehicles.
(2) Whenever requirement is declared by this article as to distance from which certain lamps and devices shall render objects visible or within which such lamps or devices shall be visible, said provisions shall apply during the times stated in subsection (1) of this section in respect to a vehicle without load when upon a straight, level, unlighted highway under normal atmospheric conditions, unless a different time or condition is expressly stated.
(3) Whenever requirement is declared by this article as to the mounted height of lamps or devices, it shall mean from the center of such lamp or device to the level ground upon which the vehicle stands when such vehicle is without a load.
(4) Any person who violates any provision of this section commits a class A traffic infraction.
42-4-231.....
When lighted lamps are required by section 42-4-204, no vehicle shall be driven upon a highway with the parking lights lighted except when the lights are being used as signal lamps and except when the head lamps are lighted at the same time. Parking lights are those lights permitted by section 42-4-215 and any other lights mounted on the front of the vehicle, designed to be displayed primarily when the vehicle is parked. Any person who violates any provision of this section commits a class B traffic infraction.
It don't matter what lights are on or even if you've got no functioning forward facing lamps during the day.
Old Dec 12, 2007 | 12:20 AM
Dan's HHR's Avatar
Originally Posted by MWG2
Duct tape over the parking lights....works every time!!
Old Dec 12, 2007 | 01:11 AM
Violet_HHR's Avatar
Unhappy
jx3, thanks, I did miss that provision. So I guess I won't get ticketed.
I still don't like it.
No, parking lights are the low wattage filaments in the amber bulbs, the driving lights are done by using the high wattage filaments normally used for the turn signals. Been done that way on Chevys for many years now. I suspect that they've moved to the headlight DRLs for one main reason - the amber bulbs get really hot, and tend to fail often, even when they're the correct bulb with the high temperature base.
[sarcasm]Oh goody, so I'm going to be blowing through bulbs and driving with no turn signals. Lovely.[/sarcasm]
Old Dec 12, 2007 | 01:21 AM
Just don't go running around w/ just your "ambers" at night!
Old Dec 12, 2007 | 01:50 AM
shaginwgn's Avatar
Didn't Corey Hart do that song "I wear my amber lites at night"?
Old Dec 12, 2007 | 05:48 AM
captain howdy's Avatar
I highly doubt it........They don't burn out that fast. I have an 06 like you and I haven't had to change either amber bulb in over 2 years and 42,000 miles. The only bulb I've had to replace other than for cosmetic reasons was a tail light.
