Sunroof functions
Old Mar 12, 2014 | 08:22 PM
Snoopy's Avatar
Fireman.......
Are you saying when you engage the tilt button your sunroof window tilts about 3 inches?
Strange, mine only tilts about 1 inch (roof line to window). But I thought ORIGINALLY mine tilted more than that. I asked a question on the forum about that several months ago. I thought MAYBE I did something to the mechanism when I removed the headliner and repaired the windscreen.
But to the OP.....mine just tilts directly to that position. It does not rise an additional height then lower, to the 1 inch.
Old Mar 13, 2014 | 04:22 AM
Snoopy. I would say it's closer to 2 inches. That 3 inches was kind of a guess, so just disregard that.
If you looked at the 1st picture, it shows it fully tilted.
Old Mar 13, 2014 | 12:52 PM
MurderMittenSS's Avatar
Originally Posted by Snoopy
Fireman.......
When hitting the tilt switch I get MAYBE 3/4 of an inch of tilt. Once raised to that height, if I press and hold the tilt button again it will raise to the 2-3 inch height and then automatically lower back to the original 3/4 inch height. Sounds like we are having roughly the same issue.
Old Mar 14, 2014 | 08:02 PM
So this is my sunroof in the tilt position. Just barely high enough to allow air in.
And this is a short video of when the roof is "tilted" and I hold the tilt button for a few seconds. I am not hitting the button a second time to lower the glass, it does this on its own.
https://www.dropbox.com/s/g2o5tl8yr5...2019.02.25.mp4
Old Mar 16, 2014 | 09:32 AM
SOLVED THE PROBLEM! It seems as if the vent function seemed to have lost its positioning, which is the reason I could raise it to two different heights as shown in the video. All I did to remedy the problem was vent the glass open, and then press and hold the vent button to open again for 20-30 seconds. I then closed the sunroof and pressed the vent button one more time to open, and the glass raised to the 2-3 inch height that it should of been at all along! I'm very glad I didn't have to take it to the dealership.
Old Mar 16, 2014 | 11:08 AM
Glad you figured it out.
Fwiw. I couldn't get your picture or video to open. That's why I didn't comment on them.
Old Mar 16, 2014 | 01:45 PM
Snoopy's Avatar
Hmmmmmm.....
Now you have me wondering. If I do the same procedure, will my vent open wider than the 1 inch it now opens. First chance I get, I'll try it.
Glad you got it corrected also.
Old Mar 30, 2014 | 09:42 AM
HHRUNNR's Avatar
When I closed my sunroof from the vent position it made a loud/fast clicking noise while closing..then popped right back open. Now it won't close all the way..anyone else have this issue and is there a solution?
Blue Beast (aka Boydie)
Mar 12, 2013 10:55 AM
Mar 7, 2013 05:08 PM
10RedSS
May 8, 2012 09:34 PM
nacorona
Jul 10, 2011 04:24 AM
teech
Jul 5, 2008 09:56 PM
