syphoning gas from tank
Old Oct 4, 2015 | 10:05 AM
JMichael's Avatar
Has anyone removed the anti syphoning screen from the gas filler tube, or found a way to syphon gas from their tank? (spending 5 months boon docking in the desert with a small gas generator to supplement the the 7.5K diesel generator)
J Michael
2008 HHR "toad"
2001 Newmar KADP
Old Oct 4, 2015 | 01:38 PM
Nope never even thought about it.
Old Oct 4, 2015 | 07:14 PM
Too much trouble to siphon.
Maybe take the fuel line under the hood loose, insert a long hose, turn on the ignition key and let the electric fuel pump fill up your container.
Or have a selectable t-valve installed in the fuel line and do the same method.
For safety reasons, I don't really recommend this, but since you asked....................................
Old Oct 4, 2015 | 08:33 PM
Lucky's Avatar
Removing the "anti siphon valve" is not a good idea.
The ball that's in the filler tube is not there to make it difficult to siphon fuel it's there to close off the filler tube in the event of a roll over.
As mentioned above pulling fuel from the engine compartment is not recommended.
I have taken samples of fuel from the fuel rail at the fuel pressure test port using the hose from a fuel psi tester.
I think you would be better off talking a fuel can with you.
Old Oct 4, 2015 | 11:20 PM
X2, carry a fuel can designed for transport in a motor vehicle, or mount a "Jerry Can" externally.
Old Oct 5, 2015 | 12:04 AM
x3 - having a second can of fuel (assuming you have one already) would be so much easier, and safer.
Old Oct 5, 2015 | 07:14 AM
And since you're going into the desert, why not go for Jerry Cans and they you can give it the look of a WWII British Army "LRDG" Rat Patrol Chevy WD-30 Truck?
These "Long Range Desert Group" Chevies not only look cool, but their ability to haul tail across desert terrain and harass advance elements of the German Army, kept Rommel from winning the North African Campaign.
ray
Feb 18, 2007 11:56 PM
calgaryhhr
Nov 14, 2006 01:11 PM
jwolfe99
Aug 23, 2006 07:27 AM
SindyDix
Aug 10, 2006 12:58 PM
SIHHR
Aug 10, 2006 10:55 AM
