Time for a smoke test - P0171 issue
Old Dec 30, 2022 | 01:10 PM
  #41
Bonez's Avatar
Originally Posted by BERNS
Replaced the solenoid but when blowing through it, one side will allow to blow through and the other it won't. Checked it with another one and it was the same. My old one was the same way. Are they not supposed to allow air from both ends?
I know it is running rich cause I can smell it when it is running so it is pumping more fuel than normal. Gets to a point that I can't stand the smell and have to shut off after testing for a few mins.
if it is cold out you will smell it rich until it warms up, make sure it is at operationg temps when testing anything.
Old Dec 30, 2022 | 05:46 PM
  #42
The reason it is rich is because a lot of unmetered air or a shortage of burned gasses is getting to the #1 O2 sensor, making the computer think it is lean so adding fuel to the A/F.
Old Dec 31, 2022 | 12:33 AM
  #43
Bonez's Avatar
True but also the cat isnt operating yet either.....
Old Dec 31, 2022 | 07:28 AM
  #44
Little Hhr's Avatar
Just in case you need a cheaper way to go.
Just as an example. I actually have 9 Hhr's at my location
hotwireflyer
Drivetrain (Excluding Engine)
May 3, 2025 02:05 PM
Rberry3000
Jun 22, 2022 11:48 AM
Mrdjc
Aug 6, 2016 01:16 AM
donbrew
Jan 26, 2014 06:45 PM
bad03xtreme
May 7, 2012 02:38 PM
